Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 11-03-2009, 08:54 AM   #1
JW76
JW76's Avatar
TPI 350 (roller) and 12 bolt axle
$200 - 350 TPI motor out of an 87 Firebird Trans Am GTA. L98 shortblock B2L Iron head option. Factory roller lifter motor. I bought the engine to run as was but then started to check it out and found that the oil pan gasket shredded and clogged the oil pickup. I then started to go through the motor. One piston had a cracked skirt. I never continued with the motor from this point. Motor is standard bore with very little ridge on the cylinder walls. Also, the crank due to the clogged pickup has very light scratches on it. Crank is not turned and is standard diameter. Could be turned and used. The cracked piston and rod went to a mechanic to look at and never got back. So you get the assembled shortblock minus the bad piston and that one rod. The heads are still bolted on. The TPI is disassembled and boxed. It is complete, has the harness to the firewall, but no computer.
$100 - 1980 12 bolt axle 5 lug with open differential. It is either a 2.73 or 2.76 and spins fine. Has backing plates. Needs brakes.
Will post pictures soon. Pickup for items please. Thanks.
JW76 is offline   Reply With Quote
Old 11-16-2009, 01:42 PM   #2
JW76
JW76's Avatar
Re: TPI 350 (roller) and 12 bolt axle
still available
