Old 11-04-2009, 06:06 PM   #1
Razr
3/4ton kickdown cable
Hi i have a 1969 GMC 3/4ton and i dont think i have a kickdown cable on it.Is there a kick down cable even available for my truck.
Razr is offline   Reply With Quote
Old 11-04-2009, 06:13 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: 3/4ton kickdown cable
What transmission are you running? If it's a TH400, the kickdown is electric.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-04-2009, 06:35 PM   #3
Razr
idk how can i tell what transmission i have
Old 11-04-2009, 06:44 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Here's a link, look at the pan.
http://www.nastyz28.com/chevy-transm...tification.php
Beat it to fit,
Old 11-04-2009, 07:00 PM   #5
Razr
Yes I have the THM400 transmission....so the kick down cable is electric were is it located..I have a edelbrock 4 barrel carb
Old 11-04-2009, 07:07 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
I believe the switch in '69 would have been on the carb. There's a little electrical connector on the driver's side of the transmision that it would have been wired to. There's a also an orange wire I believe in the engine bay for 12 volts, though any 12 volt key on source will work.
Lokar makes a TH400 kickdown setup that I'm running. Works pretty well, though a little pricey.
Beat it to fit,
Old 11-04-2009, 08:14 PM   #7
john
member #16
john's Avatar
heres a pic of what should be on a 69.
john is offline   Reply With Quote
Old 11-04-2009, 08:22 PM   #8
Razr
so it should be on the carb......can anyone show me pics of this...plz
Old 11-04-2009, 08:25 PM   #9
mclairmo
You can also use a nitrous oxide full throttle micro switch and bracket bolted to the carb to activate the kickdown at full throttle. About $15. Much cheaper than the other alternatives, like Lokar, B&M, oem, etc.
mclairmo is offline   Reply With Quote
Old 11-05-2009, 12:47 AM   #10
Razr
can someone plz expand on the electric kickdown cable how does it work
Old 11-05-2009, 09:34 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
Factory setup is a switch that sends 12 volts to the transmission at WOT. The Lokar setup is a cable operated switch that does the same. Here's a link to the Lokar kickdown switch. You'll need their throttle cable bracket as well. http://www.summitracing.com/parts/LO...s/?prefilter=1
Beat it to fit,
Old 11-05-2009, 12:39 PM   #12
CrashBob
CrashBob's Avatar
Hey,
I have the switch and mounting bracket if you would be interested.
CrashBob
"Life is all about ass. You're either covering it,laughing it off, kicking it, kissing it, busting it or trying to get a piece of it.
CrashBob is offline   Reply With Quote
Old 11-05-2009, 01:39 PM   #13
Razr
Can someone plz show me pics of the kickdown cable and switch...im curious....thanx
Old 11-05-2009, 01:50 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
There's no cable on the factory setup. John posted a pic of the switch.
Beat it to fit,
Old 11-05-2009, 02:00 PM   #15
Razr
ok heres my setup were would the switch go or be located how would it connect.....
Old 11-05-2009, 02:04 PM   #16
Sinister
Between Trucks...
Sinister's Avatar
Don't know if the factory switch that John posted a pic of will work with an Edelbrock carb. I would just spring for the Lokar switch and bracket and be done with it.
Beat it to fit,
Old 11-05-2009, 02:08 PM   #17
Razr
so your suggesting the lokar switch and bracket..were would it connect...thanz for the help sinister i appreciate it
Old 11-05-2009, 02:14 PM   #18
Sinister
Between Trucks...
Sinister's Avatar
The Lokar set up is a cable operated switch. Bracket hooks to the carb, cable hooks to the carb. Switch box goes down on the frame next to the transmission, there's holes in the frame already. 12 volts to the switch box, wire from the switch box to the transmission. Takes about 30 minutes to install. I'll try and get some pics.
Beat it to fit,
Old 11-05-2009, 02:24 PM   #19
Sinister
Between Trucks...
Sinister's Avatar
1st pic: cable at the carb with bracket, You have to order the bracket separately. 2nd pic: Switch box mounted to driver's side frame, directly across from the transmission.
Beat it to fit,
