The way my alternator bolts up....
I did not take enough pictures when I took my engine apart, now that I'm nearing completion on it I've run into a problem. My alternator was bolted on with a large curved bracket, if I bolt it like most people do the pulleys will not line up. I don't know how well I put that into words, but if somebody knows what I mean and has a solution fill me in. A picture of how it can work would be great.
Under Construction
Re: The way my alternator bolts up....
iirc, you need a spacer to line it up.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Sounds like a plan. Thanks.
Under Construction
look at this post, are your brackets like this or different?
http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Yes! My bracket is like that one.
