Old 11-07-2009, 07:59 PM   #1
TLoz
Finally finish burb soundproofer
I finally finished installing soundproof in the suburban. Man, there's a lot of acreage in that thing.
TLoz is offline   Reply With Quote
Old 11-07-2009, 09:52 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Finally finish burb soundproofer
Good Job, I know thats a lot of work, I know my blazer was but a burb. Wow!
tvblazer78 is offline   Reply With Quote
Old 11-08-2009, 12:10 AM   #3
Stitch
Location: Where I come from, it's cornbread and chicken...
nice and it's twin-sticked...very nice
Stitch is offline   Reply With Quote
Old 11-15-2009, 11:43 PM   #4
TheSunDanceKid
TheSunDanceKid's Avatar
a cheap way to do this if any one wishes to know is use roll on bedliner all sound deadener is is just weight to thicken the pannel and keep it from rattling worked professionally doing audio bedliner was always a cheaper and easier way to do it and never had to worry about pannles not fitting back on or cutting the holes out or it not sticking properly
looks good on the deadener though just throwing that out there if any one needs an easy cheap way to do it also
TheSunDanceKid is offline   Reply With Quote
Old 12-05-2009, 06:44 PM   #5
nutsforchevys
nutsforchevys's Avatar
I used this product and its not to bad.
http://67-72chevytrucks.com/vboard/s...d.php?t=374329
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 12-05-2009, 07:11 PM   #6
BGRAFX
What color interior are you going to put in?
I want to change mine but not sure what color to go with...
BGRAFX is offline   Reply With Quote
Old 12-06-2009, 09:09 AM   #7
TLoz
I'm going with a saddle/tan interior with congac carpet. Carpet is installed and most of the trim is in. Waiting for the scuff plates to get powder coated and the rear side panels to get new carpet installed. Everything else is in.
Old 12-06-2009, 04:12 PM   #8
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-07-2009, 08:01 PM   #9
TLoz
Here's the latest pictures. It's still in process. And about the red door panel inserts-the spousal unit likes them. Later, Tom
Old 12-07-2009, 10:54 PM   #10
BLE 'BURBAN
Looks damned good. I too like the red inserts on the doors adds a nice contrast to the tan interior without being ungodly gaudy. One suggestion if I might? Get one more "JESUS HANDLE" and mount it above the drivers side front door. It really helps out for climbing in & out. It also helps to make things look more symmetrical inside as well.
When i did mine, I measured the front passengers side then transferred the measurements to the opposite side. then using the proper size tap (5/16th") and the right size drill bit I drilled & tapped the holes then sliced the headliner just a bit to allow the bolts to to pass through.
Here's the only pic I have of it right now.
Old 12-08-2009, 08:32 AM   #11
TLoz
Dave,
I've got a couple of extra handles. Thought about putting one on the drivers side for a nano-second, then went on to something else. It's only a ten minute job, might as well go ahead. Thanks for the suggestion. Once I get the side panels on and the scuff plates on (out being powder coated silver), I'll snap some more shots. Thanks, Tom
Old 12-08-2009, 11:17 AM   #12
tvblazer78
Low & Fast!
tvblazer78's Avatar
Wow! Tom, that looks killer! Good job, what are the plans for the seats?
Old 12-08-2009, 12:11 PM   #13
TLoz
The seats are stock, cloth, high back buckets in front. Kinda of a gold color. All three rows are cherry. Just had to re-foam the arm rests and clean the rest-no holes or rips.
Old 12-08-2009, 02:20 PM   #14
BGRAFX
Tom that look awesome! keep up the good work.
I have one request...my drivers side right arm rest com off the other day. how do they screw back in??
Old 12-08-2009, 02:28 PM   #15
TLoz
On this suburban, the front arm rests has two screws that screw down the arm rest into tinnerman nuts inside the door. It also has one stud coming out the arm rest that attachs to the door panel itself with a tin nut.
On the rear door, it only has the two screws going into the tinnerman nuts. Different years may have different setups. Some may have the stud some may not. Hope that helps. Tom
Old 12-08-2009, 02:33 PM   #16
BGRAFX
Your other right, lol
as I'm sitting in my driver seat the right arm rest (by the center console) has a 5inch carriage bolt that screws in. My wife took the suburban to pick up the kids and came back said it fell off. don't know how but gotta fix it.
Old 12-08-2009, 02:43 PM   #17
TLoz
Oops! Sorry about that. The way I got the seat arms off was to work the cover back about 2 inches and remove the long bolt that you're talking about. It just unscrews. I assume that the seat has a nutplate or a nut welded to the frame. The bolt should have a loc-tite materail on it to keep from backing out. If you can't screw it back in, most likely need to remove the seat cover and repair the nut. If it does screw back in make sure you put some red loc-tite on it.
Old 12-12-2009, 07:55 PM   #18
ghettoluxury
ghettoluxury's Avatar
Where did you get that twin stick boot?
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-12-2009, 08:30 PM   #19
Square84
I don't think these pills work
Square84's Avatar
the carpet section that goes on the rear quarters where the 4x10 speaker holes are how did you get them off?
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 12-13-2009, 02:39 AM   #20
bigblazerboy
bigblazerboy's Avatar
looks nice. whats up with the shifter?
bigblazerboy is offline   Reply With Quote
Old 12-13-2009, 11:11 AM   #21
TLoz
The shifter is a twin stick for the 4wd. It allows independ shifting of 4wd/2wd and hi/low range. The boot came with the kit. Don't remember the supplier, maybe Colorado something-i'll find out. Always had trouble shifting in the past.
The carpet side panels are removed by removing the plastic side window trim. Then, remove the 6 screws on the pass side and 3 on the drivers side. I was out installing them last night until 12:30. What a PITA. Got it done though. Later, Tom
Old 12-13-2009, 11:24 AM   #22
TLoz
I got the twin stick shifter from Offroad Design in Carbondale CO. Phone is 970-945-7777.
Old 12-13-2009, 01:52 PM   #23
bigblazerboy
thats what i thought it was. didnt know your burb was 4wd so thats why i was curious.
Old 12-14-2009, 09:34 PM   #24
ghettoluxury
Thanks I made my own twinstick and now need a boot
Old 12-14-2009, 05:53 PM   #25
justpball
justpball's Avatar
looks hot bro!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
