Old 11-09-2009, 03:21 PM   #1
50adrod
50adrod's Avatar
keep S 10 ABS?
I am using the complete S10 harness and even the instrument cluster. it is a 96 model with a 4.3. has anyone kept the anti lock brakes, or is it just easier to delete it?
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-09-2009, 05:04 PM   #2
BlueJeep
BlueJeep's Avatar
Re: keep S 10 ABS?
It's quite a bit easier to delete it. My 95 with a 4.3 had the big module on the ds fender. I removed that and also removed the wheel speed sensors on the front wheels. You will have a check engine light unless you re-program though.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 11-11-2009, 01:34 AM   #3
50adrod
50adrod's Avatar
Re: keep S 10 ABS?
how did you reroute the brake lines to the porportioning valve?
Old 11-11-2009, 03:55 PM   #4
hotrodsbyray
Re: keep S 10 ABS?
Man, keep your ABS if you have room for the components. Would be so much safer! I am reworking the wiring for the 4.3 I am using. The ABS had been trashed when I got the engine and stuff. It actually would have been MUCH easier to use the wiring harness if I had been able to use the ABS setup.
Also, when was the last time walking around a car show you saw anybody that had ABS on a street rod?
hotrodsbyray is offline   Reply With Quote
Old 11-11-2009, 08:20 PM   #5
50adrod
50adrod's Avatar
Re: keep S 10 ABS?
just might do that
