01-20-2003, 01:28 PM | #1 |
Giddy up giddy up...
Optimas in the cold?
I've got an optima battery in the '72 (which is covered outdoors for the winter ) and temperatures at night now are around -20 degrees. Will an optima freeze and go bad like a traditional battery would, or will it be ok left in the truck? Thanks much.
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... |
01-20-2003, 02:10 PM | #2 |
check there site i have a budy that works for the army and they use them in alaska and it gets down to the -50 or low in some parts and he said that there was only one problem with one it had a crack in it
01-20-2003, 02:54 PM | #3 |
if you're worried about it, why don't you just get a battery blanket for it or surround it with fiberglass insulation for the winter. It will help it from freezing. I ran my 72 for a couple winters and I wrapped a battery blanket around it just to ease on the starting in -50 weather up here
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
