11-09-2009, 10:09 PM | #1 |
Installing New Ignition cylinder
I am trying to install the ignition cylinder in a 72' C10- what is the "trick" to get it to click into place?
11-09-2009, 10:19 PM | #2 |
The Older Generation
Re: Installing New Ignition cylinder
If you are installing it just stick it in the switch so that the little hole lines up with the spring loaded pin, push it in and turn it to the right. Once in a while you have to have the hole in the cylinder just a little to the left of the pin.... I'll get this right sooner or later... You have to have the key in it too. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-09-2009 at 10:30 PM. |
11-10-2009, 12:37 AM | #3 |
how do you get the whole assembly out of the dash i figured it just unscrewed but mine just continues to turn.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
11-10-2009, 12:46 AM | #4 |
Ok i used the search function. But thanks anyway
