View Poll Results: What engine do you want in your truck?
Small block 21 24.14%
Big block 10 11.49%
LSx 38 43.68%
LTx 5 5.75%
S10 engine (for S10 swap) 1 1.15%
Orininal engine to the truck 4 4.60%
Other (what and why) 8 9.20%
Voters: 87. You may not vote on this poll
Old 11-10-2009, 03:48 PM   #1
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
What enging do you want in your truck?
Ok i did a quick search and didn't find a poll about what engine to use.
If you could put any engine in your truck what would it be and why?
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 11-10-2009, 04:25 PM   #2
AndyL
Re: What enging do you want in your truck?
6.2 / 6.5 diesel... Why not?
AndyL is offline   Reply With Quote
Old 11-10-2009, 04:52 PM   #3
blackdiesel
blackdiesel's Avatar
because a cummins is better???
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 11-10-2009, 07:18 PM   #4
AndyL
No question a cummins 12v is a better engine... But - it comes with headaches for swapping - ie beefing up frame/suspension to handle weight & torque involved.
6.2/6.5 while not sexy - still roll the coal, are relatively reliable, and stupid simple...
Only other option is that F*rd monstrosity... Binders should stay in tractors
Old 11-10-2009, 05:44 PM   #5
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
alcohol burning 632ci w/ littlefield 14-71.... why? because Fast is fun
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 11-10-2009, 06:45 PM   #6
MrTucker
MrTucker's Avatar
LSX - for a realistic answer ()
Cheap and easy to come by, relatively easy to install, a lot of reliability, tons of aftermarket.......
MrTucker is offline   Reply With Quote
Old 11-10-2009, 06:48 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
tucker thats an answer I can live with but
please post what these engines are out of....my truck is on the heart transplant list
Hottrucks is offline   Reply With Quote
Old 11-10-2009, 10:05 PM   #8
MrTucker
MrTucker's Avatar
the 6.0L (about 325 hp stock) out of a late model Chevy/GMC truck/tahoe/suburban/etc is ideal. a simple head swap can net you around 500 hp. Problem is they are more expensive and harder to come by.
the 5.3L (about 300 hp stock) out of the same trucks is popular because they are everywhere and you can pick them up cheap. I've seen engine/tranny/wiring harness packages on ebay for around $2k, even cheaper for higher mileage engines (like 70k miles).
Also, engines later than 2004 (I believe) use the drive by wire system, which eliminates throttle linkages.
Package all of this up and you get an old classic truck, with a high tech drive train that has loads of power, runs very smoothly, has fuel injection, and gets decent fuel mileage - all for less than the cost of a crate engine with equal horsepower. Throw in an aggressive cam and you'll have a hell of a sounding motor that will run you 200k miles no problem.
Old 11-10-2009, 10:51 PM   #9
2manyprojects
2manyprojects's Avatar
I'm going with a 383 LT1 because I already have it, and spent too much money on it.
2manyprojects is offline   Reply With Quote
Old 11-10-2009, 11:02 PM   #10
Hottrucks
Hottrucks's Avatar
thanx thats the answer I was looking for!!!! I think 500 cady plans will have to wait...as good as my 327 runs I want a bit more everything... power and mileage.. I drive mine everyday and it's never going to be anyting more than a Kool DD I have put 3000 miles on it since I fixed the speedo 2 months ago and it has only worked for less than half the time I have been driving it... since I pulled it from the death weeds...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 11-10-2009, 11:39 PM   #11
NONHOG
NONHOG's Avatar
my GMC has a Chevy 235 in it now and I might just keep it. The hardcore guys say get a 302 Jimmy but my thought is if (IF) I swap it will be some thing I can get real good MPG after all I want a driver not a poser.
The LS engines sound pretty inviting.
Right after posting this i found a GMC 302 for maybe 75 $ Hmmmm
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 11-10-2009, 11:52 PM   #12
50adrod
50adrod's Avatar
I couldn't agree more, and drive by wire is a clean install and gives you cruise with a simple aftermarket switch. I cammed my 5.3, thre is a sound clip in my build thread.
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-11-2009, 01:00 AM   #13
Cameo Carrier
Cameo Carrier's Avatar
I'm on the same page as Sweet70beast. 348 for me too. 348's are right up there with the flathead and hemi's as the best looking engines ever in my book.
Is that a camaro bed on that?
Cameo Carrier is offline   Reply With Quote
Old 11-10-2009, 06:57 PM   #14
Coronas56
Coronas56's Avatar
505, Big block Chevy, Cause I want to be thrown back in the seat!
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 11-10-2009, 07:02 PM   #15
blackdiesel
For a cheap ls engine, go pick up a truck 5.3 out of a late model Chevy or gmc
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 11-10-2009, 07:20 PM   #16
Jack60
Jack60's Avatar
I've been thinking about the same thing, I have a 400, 327 and a 283, but I been thinking about putting a straight 6 in her......
Have 55 Cameo needs a bit of work.
62 Impala 4 door grandparents bought new
60 Vette 350 5speed
Jack60 is offline   Reply With Quote
Old 11-10-2009, 07:32 PM   #17
Indian113
Indian113's Avatar
Smile Re: What enging do you want in your truck?
I'm building a old school 283, but then I'm a OLD SCHOOL PERSON. My gray hair and beard matchs my primer paint
Indian113 is offline   Reply With Quote
Old 11-10-2009, 07:13 PM   #18
Kim57
Kim57's Avatar
BB because I'm doing the Pro-street theme and I have a new 4-bolt main bare block sitting in the garage.
Kim
Kim57 is offline   Reply With Quote
Old 11-10-2009, 07:25 PM   #19
code4
lsx is going in mine. I got it mounted last night.
It will be de-tuned to around 700 hp for starters to see how the chassis handles it.
I work with these engines as a hobby so I prefer them.
My camaro runs 9.90's with the same exact set up & gets 25 mpg.
Of course these are turbo set ups.
My truck engine I mounted last night is a 98 LS1 block, 2001 6.0 chevy heads, the front assesories & intake are 2000 chevy 5.3, and the exhaust manis are 2007 C6 corvette. I have a ton of work left to do so it won't be on the road for a long time.
code4 is offline   Reply With Quote
Old 11-10-2009, 07:31 PM   #20
poncho_villa
poncho_villa's Avatar
I would definately go LSx. The engine in my truck right now is awesome, but my work truck has the 5.3 and I like it lots. So when I need to go engine shopping again I'm goin for the 5.3 or maybe a 6.0 out of a truck. Easy swap, lots of goodies for them, reliable and good gas mileage.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 11-10-2009, 07:39 PM   #21
OrrieG
OrrieG's Avatar
I have a 350 going in mine, pulled out a 283 which I would love to put back in. But with overbore pistons running $50 a piece I cannot justify the expense at this time to get it bored.
Old 11-10-2009, 07:57 PM   #22
sweet70beast
sweet70beast's Avatar
My 50 3100 is getting a 348. Why? When I pop the hood I want people to say " What the heck is that?"
My 54 Suburban is getting a turbocharged Grand National V6. Why? Because I have one and it would look great in there.
My 50 Bus is going to get a Cummins.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 11-10-2009, 08:13 PM   #23
joeys66pickup
Dr. Frankenstein
oooo realistically? late model 6.0L from any truck or SUV with a S400 or something on it
Cheap and fun/fast
I Wanna Go Fast!!
Old 11-10-2009, 10:01 PM   #24
82GMCShortBed
82GMCShortBed's Avatar
Would love to put one of these in my 454SS!!
Nelson Racing 632CI Big Block
82GMCShortBed is offline   Reply With Quote
Old 11-10-2009, 09:56 PM   #25
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
I voted original. It would be a 248 I6 in my case. I will have to settle for the later 250 thats in it for now. It seems to run real well so what the heck. I have several other V-8 trucks so this engine in the '55 works for me!
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
