Speedway control arms
I was looking thru a speedway book and am thinking of using their upper tubular control arms, but not sure which ones I need. I have a 70 camaro clip on a 56 . My choices are a offset style or one thats centered and would my clip be metric? They also come in different lenghts from 8" to 9 1/2". I assume this refers to length from mount to center of ball joint? I am running bags so would a longer than stock arm be of any advantage?
Re: Speedway control arms
Becarefull if it's a racing application. Most don't have bearings and any bit of dirt will wear them out. As an alternative look at Joesracing.com and look at his sealed bearing control arms.
Metric chassis is G bodies from '79 to '88. The thing about circle track parts is you might have to do some fabricating to get'em to work right. For something as belly button as a Camaro clip I would just order some bolt-ons.
