Blazer rear side panels
OK....getting ready to make my rear side panels (thanks yellowblazer1969) for the blazer and I'm wondering what material will work best?
3/8 plywood maybe or ???? I plan to carpet them and install speakers in front of and behind the wheel wells plus I will be making an access panel in the very back so I can store a small tool kit and a bottle jack, tire repair kit....etc. I thought I would just screw them into the bed rails on the top and maybe use a channel to slide it into on the bottom or if nothing else I can just use some angle and screw it down there too. But, I need something skinny and sturdy that will hold carpet glue. What have you guys done or anyone have ideas?
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
Workin to live...
Re: Blazer rear side panels
3/8" would be heavy enough, but3/8" will start getting heavy if you have double wall top and have to take the panels out to get to the bolts! I'd look at the difference in price of 3/8" and 1/4". I'd probably use 1/4" and just beef up around the speaker openings and the access for price and weight!
Jason |
![]() Join Date: Nov 2009
My blazer came with some home made panels made from 1/4 hardboard (simular to MDF).
I would say this will be heavy enough, after I mount it a little better- right now it's not mounted very well and seems a little flimsy. I plan to mount speakers in mine too, and I will be "beefing up" the panel around the speaker locations & will probably use 3/4 MDF there. I'm trying to come up with some type of pattern to dress it up a little- I just have a little "creativity block" but I'm sure I'll come up with something. If anyone has any unique designs on their panels please post pictures- I promise to only use your designs as inspiration! ![]()
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
![]() Join Date: Jan 2001
I think the 1/4" hardboard is probably closer to what the stock panels had backing them up. I'll probably use 1/4" plywood when I eventually do mine, just to make them a little more durable.
If you have a trim strip along the side of the top rail, it's set up for something less than 3/8"...trust me on this!
We did 1/4" with a basic indoor outdoor--a temp fix for sure--but I still haven't figured out a satisfactory solution to the double wall install and removal. I hate the idea of pulling the panels out every spring and fall,,,
Big Red Beast 1972 Blazer CST AC/Auto/4x4 "Project" 1997 F 350 CC Powerstroke "The Great White" |
I'm selling my hard top...never plan on using it.
I'll be putting on one of the "convertible" tops from Softopper.com So, removing the panels isn't a problem. I'm more concerned with them being rigid enough to hold up. Possibly the carpet/glue will add to them and I am starting to think that 1/4" is good enough as long as I double it up at the speaker and access door cut outs. I don't have a trim at the top of the bed rail....but I'll be putting something up there. I'm with Dusty71Blazer.....if you have pics....PLEASE post them.
#7 | |
it would take some more work but could you just stop your panels 3"-4" down from the bedrail and have a trim piece that would either snap or velcro on to cover the gap- quick & easy to remove & replace. That way the main panel can stay in place & speakers, etc that are mounted in it are not affected. I am no artist but I did my best to draw what I am thinking... ![]() Just an idea, hope it helps!
I used the white plastic with bumps on one side that is made for showers and bathroom i contact semented two pieces togather worked great and held 6x9 speekers two years no trouble
I made mine out of 1/4" plywood and covered in black vinyl. It actually screwed to the mounting flanges in the back, and in the front I trimmed it where it slipped in behind the B-pillar flange that runs from the top of the bed rail to the floor. I drilled an over sized hole in the B-pillar piece, then pulled the panel out flush using a screw and trim washer. I have 6 1/2" coaxials mounted in them, and it works great. My first set lasted 12 years, and the current ones have been in there 8.
Any pic's, anybody? I want to go with diamond plate myself.
