Old 11-12-2009, 09:17 PM   #1
rob32472
4.3 to 5.3 swap
I have a 2000 4wd with a 4.3 liter engine and would like to swap to a 5.3 liter besides the harness, computer, and accessories what else would be needed to complete this.
rob32472 is offline   Reply With Quote
Old 11-12-2009, 10:30 PM   #2
clinebarger
Re: 4.3 to 5.3 swap
Besides what you have already know, you will need (from a V8 doner) Throttle cable,cruise cable,engine mount stands,Fan stroud,radiator hoses,fuel lines, And the biggest thing to consider is the trans the converter spacing is different and V6 4l60Es only have 5 3-4 clutches VS 6 in the V8 version. your best bet is to use a 5.3 trans & it has to be a 4WD trans because of the different out-put shafts. All in all the easiest 5.3 swap.
clinebarger is offline   Reply With Quote
Old 11-13-2009, 12:24 AM   #3
SkylineNXS
SkylineNXS's Avatar
Re: 4.3 to 5.3 swap
sorry for off topicidness, but is this a similar situation from going from a 5.3 to a 6.0? or is there more to that?
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 11-13-2009, 12:41 AM   #4
clinebarger
Re: 4.3 to 5.3 swap
The early 6.0 had different cranks (99 & 00) than any other LS based engine.
using a late model 6.0 all you really need is a long block
The computer & intake are the same between the 6.0 and 5.3.(The 4L80E 6.0 computers are different)
Dont count on your stock 4L60E to last long with a heavy foot.
Old 11-13-2009, 12:59 AM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: 4.3 to 5.3 swap
Brad
This guy is correct, 99-00 6.0s were iron head, and had a different crank that doesn't mount up to the 4;60e correctly.
01-07 6.0s have aluminum heads, and the crank spacer for the 4l80e can be removed and mated to a 4l60e
Everything off your 5.3 bolts on/hooks up to the 6.0, get the computer tuned and drive. But your 4l60e will not like it very much. Look into a few basic upgrades for the trans such as a shift kit, and corvette servo to give it a little more holding power.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 11-14-2009, 01:07 AM   #6
SkylineNXS
SkylineNXS's Avatar
Re: 4.3 to 5.3 swap
yea i mean idealy i would switch to a 4l80e if i were to change to a 6, but its nice knowin all it needs is a tune and it can use the same parts....thanks guys, and again, sorry for bein off topic...
BRAD
