Old 11-12-2009, 11:09 PM   #1
68 TT
Still plays with trucks
68 TT's Avatar
transfer case options
My 78 K20 currently runs an SM465 and an NP205 with 5.13 gears.
My knees are shot and I need to convert it to an automatic. I have been looking for a T-400 NP205 setup for the last year with no luck. I am on a pretty tight budget so buying a new adapter and input shaft for my NP205 and doing the machine work to the case to convert it is not likely to happen.
I would like to run a T-400. What are my transfer case options?
I am new to the 4x4 arena. I know the NP205 is very tough. How do the NP241C and NP208C compare? I know they have aluminum cases but I don't know how strong they are as far as power handling ability or how they compare to each other. I assume the T-400 versions only came in the 3/4-ton and 1-tons.
Are there any other newer transfer cases that were available with passenger side drop?
Any input would be appreciated.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-13-2009, 12:05 AM   #2
csa daddy
csa daddy's Avatar
Re: transfer case options
i got a np205 with a figure 8 bolt pattern with a 27 spline input i will let go you could put it behind a 350 turbo or a 700r4
csa daddy is offline   Reply With Quote
Old 11-13-2009, 09:41 AM   #3
68 TT
68 TT's Avatar
Thanks for the offer but with my plans to install the 4L80E I already own your 27-spline case puts me in no better situation than the 10-spline case I have in the truck now.
Both have the small 80mm input bearing and would require complete tear down of the TC, machine work to enlarge the bearing area to 90mm and a new T-400 input shaft & bearing kit. Not really in my budget at this point in time.
Old 11-13-2009, 03:59 PM   #4
csa daddy
csa daddy's Avatar
i got a 208 that is 32 splined that will hook to that 4l80e i had it in my 1 ton dually when i straight axled it i would get rid of also
Old 11-13-2009, 05:34 PM   #5
68 TT
68 TT's Avatar
That is what I am looking for just not 3000 miles away. Thanks for the offer.
Old 11-13-2009, 12:29 AM   #6
CG
BlahBlahBlah
I think Wes ClassicHearbeat on the board has a turbo 400 np205 set up for sale.
My thoughts were this was the way to go for strength. But I was talking with Mark Livrat about it and he's run the turbo 350 np205 set up in his big block 4x4 for many years with no problems.
Old 11-13-2009, 09:35 AM   #7
68 TT
68 TT's Avatar
I don't have any problems with a T-350 I just already have a 4L80E that will go into the truck down the road and need the T-400 spline TC to make it work.
Old 11-13-2009, 01:19 AM   #8
shilo
shilo's Avatar
i ran a 454, turbo 400 and 208 with 44" tires and never had a problem. t-400s and 208s are alot cheaper than a 400/205 combo
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 11-13-2009, 07:01 AM   #9
ghettoluxury
ghettoluxury's Avatar
I have never had a problem out of a 208. If you do run a 208 you get lower gear ratio, 2.6:1 rather than the 1.96:1 that the 205 has.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-13-2009, 09:33 AM   #10
68 TT
68 TT's Avatar
That is good to know, thanks.
What year range will I find an NP208 with passenger side drop?
Once I get the transfer case situation figured out and get all the automatic conversion parts I will put in the T-400 and all the matching parts to get the truck back on the road.
I have most of the parts I need to do a TBI conversion and also have a 4L80E that will go in as part of that swap but I need to get the automatic conversion done first so it is not so painful to drive the truck.
Old 11-13-2009, 12:55 PM   #11
olblue60@aol.com
member
I put a built up 700r4. You are kinda getting a rebate on the price everytime you stop for gas. The ratio is about .7 to 1 instead of a 1 to 1 ratio with the 350 or 400. I believe that in about 10,000 miles, it will pay for itself. Plus 1st gear is lower than either of the other trans as well.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 11-13-2009, 01:41 PM   #12
68 TT
68 TT's Avatar
I already have a 4L80E that will go into this truck but needs to wait until I get the rest of the TBI conversion parts accumulated and can do the engine swap so the computer controls are present for it to operate.
I do very little freeway driving and a lot of stop & go so the T-400 not having OD won't really bother me much. I really need the automatic more than anything. With the 5.13 gears and a manual trans I am shifting on average 150 times in a round trip to work and back through town. Not really good on a pair of bad knees to use a heavy truck clutch that often. The SM465 is in need of a rebuild too with all the shifting it has done so I might as well save the rebuild money and put it towards the automatic conversion instead.
I will be looking for an 81 to 88 NP208 with a T-400 so I can use the TC components with the 4L80E swap down the road. I will still keep my eye out for a T-400 splined NP205 but they are pretty hard to come by up here used. Nobody wants to get rid of them.
Old 11-13-2009, 05:38 PM   #13
csa daddy
csa daddy's Avatar
my bad didnt realize how far ya was
Old 11-14-2009, 08:44 AM   #14
Dooley
Dooley's Avatar
The CUCV's, ex-military 4x4 Chevy's have the T400/208 setup. There are a few pickups/chassis cabs that have the T400/205 but, they are not as common as the 208 setup. The M1009 Blazer has the T400/208 as standard equipment.
My M1008 has the T400/208.
Dooley is offline   Reply With Quote
Old 11-14-2009, 09:39 AM   #15
ghettoluxury
The 88-91 NP241c will also work and it has the electric speedo.
