11-13-2009, 05:11 PM | #1 |
One piece drive shaft
Is is common for an '87 GMC Suburban to have a one-piece driveshaft? It's equipped with a TBI 350 with 700r4 trans. 2 wheel drive, 1/2 ton.
I have a 90 and had an 85, and they both were/are equipped with a 2 piece DS, both 350s with the 700r4, 2 wheel drive, 1/2 tons.
Robert Member 1532 Last edited by 90\87Formula; 11-13-2009 at 07:27 PM. |
11-13-2009, 06:24 PM | #2 |
Re: One piece drive shaft
Is it 2wd or 4x4? Both my 4x4 Burbs have a one piece drive shaft and the two 2wd Burbs I've had came with a 2 piece drive shaft.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
11-13-2009, 07:23 PM | #3 |
It's 2wd.
Robert Member 1532 |
11-13-2009, 09:30 PM | #4 | |
Ironmonger
I wonder what the critical RPM is on a one-piece shaft as long as the one in a Sub. Last edited by JEM; 11-13-2009 at 09:30 PM. |
11-16-2009, 06:27 PM | #5 |
Both of my 2wd (82 and 84) burbs were 3/4 ton. Maybe that might be a factor.
11-13-2009, 07:50 PM | #6 |
Truck Nut
I have seen alot of burbs,,,,2wd.....all 2 piece.
Tony Kee Texas Square Bodies |
11-13-2009, 08:37 PM | #7 |
huh ???
I was at the junkyard 3 days pulling a trans out of an 87 burb. 1/2 ton 2wd 350 w/ 700r4 trans. The truck had a 1 piece shaft in it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-13-2009, 09:07 PM | #8 |
1987 was my old burb. Same config. 1 piece driveshaft
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options 1967 Chevrolet C10 Longbox Stepside - Restored 1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled 1987 GMC Suburban 1500 - Now some retired guy's trailer hauler 1992 Lumina Z34 - I'll miss that PITA |
11-17-2009, 12:17 PM | #9 |
A suburban has the same wheel base as a long box pickup (137.5 in), so it shouldn't be all that uncommon to see a one piece drive shaft.
I can still count my vehicles on two... wait three hands. |
11-17-2009, 11:53 PM | #10 | |
huh ???
Chuck
11-17-2009, 11:58 PM | #11 |
my short bus
I think it is where it was built cause my 77 had a 1 pc
but my 91 and 87 both 2 pc
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
