11-14-2009, 11:55 PM | #1 |
Well, Whoop-dee-do!
Performance brake parts? I wanna stop!
Anyone running performance pads and/ or drilled & slotted rotors on the front? I'm getting tired of so- so brakes on both my 1/2 and 3/4 ton 4x4s. they both have 33" tires. It seems like the expensive parts store pads are as hard as granite and you have to use both feet on the brake and blow your knees out just to slow down. The el cheapo pads stop with much less effort, but fade bad in high speed panic stops or when coming down a hill.
When I can afford it, I'm thinking of trying drilled & slotted rotors with EBC "yelllowstuff" pads. I don't care about dust or if I need new rotors after one set of pads. I want to STOP when I need to, not just slow down. But I don't want to spend a fortune on trick calipers & such. Neither of these trucks log many miles either- maybe 5k a year the most. What have you found to work good?
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
11-15-2009, 12:16 AM | #2 |
Re: Performance brake parts? I wanna stop!
My thoughts...
I thought the drilled and slotted rotors were to help cooling and prevent fade, especially in towing and race applications. Maybe they help clear debris. I think true stopping power is a matter of surface area, diameter of the rotors, piston number/pressure applied, amount of vacuum assist/hydro assist, quality/age of brake fluid, and even brake pad type. In other words, I doubt switching to slotted/drilled rotors would do much. Pads...maybe so. I've changed the vacuum hose alone and it made a dramatic difference in brake pressure needed. i.e. make sure all your stuff is in working order. The larger the tire the more work needed to stop, also!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
11-15-2009, 05:00 PM | #3 |
Well I wanted my 4000lbs of runaway GMC to stop as good as possible given its a 37 year old, 3/4 ton, solid axle, 4X4 truck so I have bought Yellowstuff pads, and cryoed stock rotors. (Well I sent my rotors off, the guy took my money and he sent my rotors back!).
No help at all in regards to before/after comparisons. Still stuck rebuilding. On a side note my lathe guy didn't want to slot my rotors for me so I settled on making sure they were round (true). Three out of the four rotors I bought needed work. Any disc runout can cause longterm headaches too.
1972 K2500 Long Box 400/350 |
11-15-2009, 07:56 PM | #4 | ||
Well, Whoop-dee-do!
Have you ever driven a big Mopar from the mid 70s? Most of them would throw you thru the windshield if you breathed on the brake pedal. Nothing trick on those old boats, but they had awesome strong brakes. Too strong for some people- customers would come in the shop back in the day complaining about them. I wish I brakes like them. Quote:
11-15-2009, 09:38 PM | #5 |
I noticed this also, the R should have been a dead give away it was on the wrong side. I see you decide to use the caddy rear calipers to retain your e-brake.
1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 11-15-2009 at 09:40 PM. |
11-16-2009, 12:10 AM | #6 | ||
1972 K2500 Long Box 400/350 Last edited by Billhilly; 11-16-2009 at 12:11 AM. |
11-16-2009, 02:28 AM | #7 |
Sb 400 club
I have heard great things about the rear disc swap. I will say that after adding a lift (with new brake lines) and 34' swampers I have found the brakes to be a bit weak. Truck felt alot better before. Maybe more adjustment.... but hydroboost or rear disc might be in the future
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
11-16-2009, 12:24 PM | #8 |
Page intentionally left blank.
Depending on what you're running, SSBC makes an oversize caliper setup called Big Bite. I know they have it for the D44 front, not sure of others. Spendy though, I think it's $800 for the D44 setup.
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
11-16-2009, 05:22 PM | #9 |
Well, Whoop-dee-do!
Billhilly, I guess I didn't read your first post correctly. I seen "no help at all" and jumped the gun thinking they didn't help. Now I understand, you don't know yet!
Big DUHH on my part. WyoRoadDog, yep both trucks have 44 fronts. One 8 lug, one 6. $800 calipers is crazy! You can try a set and let me know how good they are
11-16-2009, 07:24 PM | #10 |
I put one ton brake master and booster on my half ton and it stops better than my new silverado. Easy swap and cheap too.
11-19-2009, 11:31 AM | #11 |
11-22-2009, 02:59 AM | #12 |
depending on what size rims you are running now...there are a couple options if you want all off the shelf parts (which I think would be a plus compared to a spendy kit). i have seen people use the rotors from a P30 van, which are bigger than even stock D60 front axle rotors, along with ford super duty calipers and a custom mount. this was on a dana 60 though, not sure if it would work on a 44.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
11-18-2009, 11:14 AM | #13 |
You may have to wait awhile, I'm planning on getting them just after I win the lottery!
11-18-2009, 10:42 PM | #14 |
double post please delete
11-18-2009, 10:43 PM | #15 |
Are the disk brake conversions for the cost?
11-19-2009, 12:41 AM | #16 |
Windy Corner of a Dirty Street
My question too! I am looking to ditch the rear drums on my 14 bolt full-floater and need Caddy rear calipers as I have a manual trans and need a park brake. Looks like a $500 conversion so I am curious to hear others experience with this as well to see if it is money worth spending.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
11-16-2009, 10:43 PM | #17 |
HydroBoost and 4 wheel discs Does wonders on 33's and up.
Billhilly, the caddy calipers are a great choice since you need to retain your e-brake. They will stop just as well as the front calipers do.
1949 Five Window, 1973 Step Side, 2000 Z71 |
11-17-2009, 11:16 PM | #18 |
Everything is work in progress
Easiest way to get better brakes is to use "softer" pads and top of the line brake fluid, they don't last as long but are very "grippy". Slotted rotors are only for cooling and will not improve braking only cooling. Larger rotors, bigger calipers a different mc will help your braking. Rotors and pads that are designed to work together are the best combo.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
11-25-2009, 05:55 AM | #19 |
Is there a big brake kit for a front dana 60?
11-26-2009, 04:21 PM | #20 |
Anyone know a part number or have a description of the Cadillac E brake calipers? And will these work on a 8 lug ¾ ton Eaton safely? What rotors do you use?
11-26-2009, 08:28 PM | #21 |
My (Caddy) calipers are off a 76-78 Eldorado, would work fine on your Eaton. My rotors are off a 71-78 Chevy 3/4 ton 4X4. I'm guessing but would think they would fit too. Just need brackets.
Post #1 huh. Welcome aboard!
11-26-2009, 11:55 PM | #22 |
Jonny
I have 285/75r16 (33x11.5) on my 3/4 ton and it will lock them up if you hit them hard enough. I've also pulled a trailer with a half ton long bed on it and no trailer brakes and didn't have any troubles. It didn't stop on a dime, but definately stopped well enough to be safe going down the road.
I am running hydroboost and crappy duralast pads (I was broke and needed brakes). I'd say that any of you who hate your brakes either have a problem of some kind in your sytem or need to switch to hydrboost. If you have a D60 and want upgrade your brakes with off the shelf parts, you can swtch the outers to Ford and from what I've been told they have twin piston calipers and larger rotors. Edit: I forgot to mention, If you switch over to rear discs you also need to install a disc/disc master cylinder and proportioning valve. I'm sure you guys who have done it know this, but since I hadn't seen it brought up in this thread before I figured I would. Now as far as where to get one, I don't know. I know that the 88-98 3500HD's (the ones with a straight front axle) used hydroboost and had a disc/disc set-up with a either a Dana 70hd or 80 which it was illudes me at the moment. You may be able to use that master with the 73-87 booster. this is an avanue I was looking to explore.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 11-27-2009 at 02:07 AM. |
11-29-2009, 09:19 PM | #23 |
Well, Whoop-dee-do!
I'm pretty set on going ahead with a hydroboost setup on my '72 K20. I junked out a '77 C30 about 6 years ago. A friend still has the remains. I checked it yesterday and the HB is still there. It was working when I junked it out, so it should still be good.
Probably be a while until I get 'round toit though
11-29-2009, 11:46 PM | #24 | |
12-08-2009, 07:43 PM | #25 |
We finally changed out the gear box (too much slop) rag joint, master cylinder and brake booster today. I upgraded to a 1 ton master and booster and the change out was quite simple until I got to the P valve lines that run to the master. After much thought I went to NAPA and bought some straight tubing and ran new lines. The truck is a 72 1/2 ton 4X4 short box with the original brake system in it. Just checking in...I will know the full extent of the 1 ton upgrade later.
