Old 11-15-2009, 12:09 PM   #1
bradford
is this a weld on or bolt on piece?
I need to repair or replace this. I dont want to patch as much as possible.
Does it bolt on or is this weld on? Its an inner cowl panel.
http://www.gmcpauls.com/pictures/inn...tchpaneldr.jpg
Thanks.
bradford is offline   Reply With Quote
Old 11-15-2009, 12:16 PM   #2
mr48chev
mr48chev's Avatar
Re: is this a weld on or bolt on piece?
It welds on. I think there are a series of spot welds around it that have to be drilled out to do it exactly right.
If you don't have the nose off the truck yet Coyotedav's thread shows some fairly decent photos of the front of the cab and you can see how it goes together. Spot welded and seam sealed. http://67-72chevytrucks.com/vboard/s...d.php?t=371676
Old 11-15-2009, 12:43 PM   #3
mbgmike
Yes it welds on ..They were spot welded at factory so you will have to Plug weld the part to get it close to factory. Unless you want to invest in the equip to do it like the factory.
My nephew is in 1'st cav over their in Irag. He's from Las Vegas. Supposed to be back next month to FT Hood.
Good Luck
I guess you could bolt it on if you wanted to. I would just weld in on
I think they were describing that the panel is under the top cowl cover, which is bolted on.
mbgmike is offline   Reply With Quote
Old 11-15-2009, 12:43 PM   #4
bradford
It says its a bolt on but i dont know.
http://www.gmcpauls.com/Body&Bumpers.htm
Old 11-15-2009, 12:56 PM   #5
bradford
Cool. Thanks for the info.
I may know him. Thats my unit.
Old 11-15-2009, 01:20 PM   #6
mbgmike
PM'd his name
