11-15-2009, 12:48 PM | #1 |
ok whats the trick?
my truck leaked tranny fliud on my cement driveway, and yes i know this dont have much to do with the truck but..., i tried a hundred things from my hardware store with little to no luck getting it out. anyone know how to get oil and tranny fluid out?
"I'll keep my guns, money, and freedom. You can keep the "change" |
11-15-2009, 12:51 PM | #2 |
Happy to be here
Re: ok whats the trick?
It's hard to get it up because of the red color that's in it. I found that a healthy dose of swimming pool shock works great on stubborn stains.
11-15-2009, 01:00 PM | #3 |
thanks ill have to try that. will that bleach the rest of my driveway though?
11-15-2009, 01:23 PM | #4 |
get a bag of stay dry or kitty litter and work it into the spot real good. do it over and again a few times and it will probably remove most of it so long as the fluid hasnt been baked in
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-15-2009, 02:06 PM | #5 | |
I did this on a driveway where the tenant let his "Ford" sit for months thereby marking it's spot with a huge trans/oil stain. Of course the spot was cleaner than the rest of the driveway but once I blasted it with a pressure washer it looked better. |
11-15-2009, 02:43 PM | #6 |
.. !WAR FEDOR! ..
this sounds wierd, but i do it at the hangar where i work whenever we have leaks in our birds, we use gas and detergent and scrub it in to the stain. wipe it up and then work the kitty litter that everyone said. works wonders
"san diego chargers #1" |
11-15-2009, 03:01 PM | #7 |
I just use Gunk Engine Cleaner. spray it, let soak, maybe scrub w/ nylon brush, blast off w/ pressure.
11-15-2009, 05:44 PM | #8 |
Extended cab fanatic
I use Brake Cleaner, and a rag in my shop. Works real good, but it probably depends on how porous the concrete is on the surface.
If it has a motor, it has my attention. |
11-16-2009, 12:38 AM | #9 |
this concrete is kind of porous..i tried brake clean and foamy engine degreaser with a powerwasher.. and bleach.. and a couple things off the shelf at home depot. i didnt even think of kitty litter.. im going to try that and some of the other things posted. thanks!
11-16-2009, 12:24 PM | #10 |
you can buy concrete etch at lowes or home depot and should take anything out
11-16-2009, 12:28 PM | #11 |
Master Hater
kitty litter and a short piece of 2x4 , or any wood block and use the block to grind the kitty litter in to a powder and grind it into the stain. let is sit a few days and sweep off.
