Old 11-15-2009, 06:17 PM   #1
scott123
factory tach dash
i need a good vendor for the circuit strips for my factory tach dash...everything works except for the temp gage....strip is bad....s.
scott123 is offline   Reply With Quote
Old 11-15-2009, 06:21 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: factory tach dash
Did you try working the mounting nuts back and forth a little? I had the same problem, and it ended up being loose contact. Otherwise if it is bad, I have heard the repop that Brothers sells is well made.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-15-2009, 07:45 PM   #3
JimKshortstep4x4
If you work carefully it is possible to repair the strip by soldering a small jumper wire over the bad spot.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-15-2009, 09:08 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'd assume all the repop circuit panels are the same, but I know several that have used the one sold by Classic Parts of America (the old Chevy Duty).
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-16-2009, 07:48 AM   #5
scott123
maybe i had never been looking for one but i aw one in Classic Chevy last night. I may tru to solder across the bad spot. So far I can't locate the actual cause. I think I will make the solder attempt and try it just in case there is something causing it I have not found. Thanks. Scott
Old 11-16-2009, 09:05 AM   #6
KEL
72 GMC
KEL's Avatar
didn't GM make a "solder pen" for repairing the
rear window defroster ? Might be worth a try.
KEL is offline   Reply With Quote
