Old 01-21-2003, 02:57 PM   #1
Chevy87blazer
how to change a neutral saftey switch
How do i change the neutral saftey switch on a 87 S10 blazer.. or better yet how do i find out if its bad???
Chevy87blazer is offline   Reply With Quote
Old 01-21-2003, 03:09 PM   #2
Prerunner1982
Prerunner1982's Avatar
try putting it in nuetral.. to see if it starts. i dont remember how much they cost. i believe on the s-10 blazer they are on the top of the column somewhere. its been 4-5yrs since i changed on.. the one on my truck went out.. had to drop the column both times i have had to do it......
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-21-2003, 03:32 PM   #3
Chevy87blazer
alright i will try that. but if that doesnt work how do i get to the switch? i need to get a digital camera and take some pic.. that would help
AIM screen name: Bpd0159 IM me if you want to.
Ditch the ***** and lets go mudding!!
My lug nuts require more tourqe than your ricer makes
Hobbies: Working on cars and trucks, Mudding, Dirt Biking, drag racing, hunting and fishing.... just anything to be out side
Old 01-21-2003, 08:14 PM   #4
Chevy87blazer
no one else knows how to help me on this one?
Old 01-21-2003, 09:03 PM   #5
Maximum Overdrive
December 21, 2012
To get to the switch you need to take apart the lower part of the dash near the steering column, you then need to unbolt and drop the column down. The switch should be about half way down the column. You need to unplug the harness and remove either two or three screws that hold it on. I'm not the best at directions so it might be easier to get a haynes manual and use it.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 01-21-2003, 09:05 PM   #6
Chevy87blazer
alright ill have to try to get one or something.....
Old 01-21-2003, 09:13 PM   #7
Maximum Overdrive
December 21, 2012
Technically it is illegal but I have seen people in the public library copying the pages they need for their repair instead of buying a manual.
Old 01-22-2003, 10:19 AM   #8
Chevy87blazer
LOL i never even thought about that... or i could go to the library and use the library card that i've had since like 4th grade!!.....but only if i knew wehre it was...
Old 01-25-2003, 12:50 PM   #9
MAC67
" SHOW ME"
MAC67's Avatar
quick fix
hey there should be 2 wires runnin into the switch when you find it,,,,,,a quick easy fix is to just cut both wires and twist them together,,,just be careful cause it wil start in gear now,,,but it save the cost of the switch..
MAC67 is offline   Reply With Quote
Old 01-26-2003, 04:09 PM   #10
Chevy87blazer
ok but how do i get it in the first place?
