![]() Join Date: Nov 2000
Spin On Filter Conversion Leaking!
I installed the spin on conversion deal on my 327 a couple of years ago and it leaks when parked when the engine is hot. Not enough to notice on the dipstick but enough to stain the garage floor. I'm tempted to go back to the canister, but how could I fix this slight leak before I give up on the spin on? Thanks.
Re: Spin On Filter Conversion Leaking!
did you try tightning the mounting bolts?
BOHICA
new or oversized O-ring? Put a little RTV on the mating surface? Either is worth a shot, I hate oil drips on the garage floor!
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
No I haven't. I do remember it being a little bit of a challenge to get that first part in; the oil valve piece then the spin on piece kinda sandwiches the other piece up there and maybe the seal is just off a bit. I could try and tighten it first. Just wondering if there was a trick to get it installed right. Is it uncommon for them to leak? Shall I try some sort of sealant/gasket maker around the bigger rubber gasket? Thanks.
Redefining LowBudget
i chased this with my truck ..what a pia ...My I ended up at a Big truck shop they have huge selections of the square O rings...I picked up one that was the correct size put a little gasket rtv and put it back to gether no more leaks
I would try to tighen it gently first if it gets worse see plan A
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
I just went through this same process last weekend. I used the Mr Gasket conversion kit (P/N 1270). After I got it installed, it leaked. No matter how much I tightened the adapter or the oil filter, it still leaked. I took it apart and found a defect in the gasket that was supplied with the kit. See the picture below. I installed the original gasket and it is leak free. I eventually need to find a new gasket (Mr Gasket told me that my only option is to return the entire kit to the place where I purchased it). My opinion is that the gasket that came with the kit is low quality. Besides the void in the picture below, it had a lot of excess flashing on it.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
#7 | |
#8 | |
Are you talking about the big o ring or the small one affixed to the part? |
