![]() Join Date: Jan 2009
removing rearend on a 69 c10????
I'm removing the rearend off of our '69 parts truck to put on my '70. I have it all loose, I have the 4 (two per side) big nuts off of the U-bolts, but the rearend is still stuck on the trailing arms and it doesn't want to come off.
how hard should it be to remove it????? any tips???? I tried searching but found nothing
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
Re: removing rearend on a 69 c10????
The u-bolts are usually rusted inside the arm. Hit them with a big hammer. You will want to replace them anyhow. Sometimes you have to put some heat to them.
more ideas than money
Spray with your favortie penetrating oil.....hit with a BFH......repeat as necessary.
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
laying low
![]() Join Date: Mar 2001
Yeah they dont' give up so easy after 40 years. Stay with it you will get it. You could always use the hot wrench on the bolts. Cut those suckers.
#5 | |
I pulled the cover and the oil looks brand new, the truck has been sitting for over 10 years. The truck has a 3.07 open diff, the same thing I already had. I wish I had the money to switch it out to a 3.73 posi. ever use SOK penetrating oil in the green can!!!! it works every time, that and a 12# sledge hammer and a 36" crowbar
