Old 11-22-2009, 06:47 PM   #1
vegaschevy
truck did not start in park, but started in neutral
Got a call form the GF telling me that the truck wont start, wont crank nothing.
I got to her and the truck was dead but did have power. Truck would not crank in park but fired right up in neutral. not sure on the back up lights but I am guessing it is either time to adjust the neutral safety switch or replace it totally.
anyones opinions? best place to pick one up if you suggest I get one? are they all the same?
vegaschevy is offline   Reply With Quote
Old 11-22-2009, 06:54 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: truck did not start in park, but started in neutral
Try adjusting it first. I got one at Kragen that works perfectly.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-22-2009, 09:02 PM   #3
pickupman
pickupman's Avatar
dont let GF drive truck.
Sounds like replaceing switch after trying to adjust it
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 11-22-2009, 10:10 PM   #4
shootiniron
How do you adjust the neutral safety switch?
shootiniron is offline   Reply With Quote
Old 11-22-2009, 10:14 PM   #5
hayhauler71
hayhauler71's Avatar
I put bigger motor in now wife don't like to drive it. adjust the switch if don,t work replace it.
hayhauler71 is offline   Reply With Quote
Old 11-22-2009, 11:02 PM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
NAPA 's got em too, about $20.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-23-2009, 06:19 AM   #7
If it`s just outside of adjustment you should be able to push hard up on the shifter and engage enough to let the truck crank.But,that could be a worn switch,too.
Old 11-23-2009, 08:39 AM   #8
cdowns
cdowns's Avatar
try adjusting first if that dont work remove and spray the crap out of it with wd40 if it's still nogood then replace
Old 11-23-2009, 12:37 PM   #9
vegaschevy
I got it started in neutral but this morning it would not work at all in park or neutral, could the switch go out in stages like that?
Old 11-23-2009, 02:38 PM   #10
vegaschevy
Picked up a new Neutral safety switch from Napa, took the old one out and plugged the new one in. She started right up.
I did have some concerns with what the new one looks like with what the old one looks like.
Does anyone have a pic of a non broken Original Neutral safety switch? I have not installed the new one on the column yet but not sure it will even work.
See the old one is broke on the left side. It appears to be wider when not broken but it does not seem to be solid, almost U shaped. the new one is a wide blade on the switch itself in white.
also the new one has more provisions for more plugs, probably other vehicles. The old one does not. has anyone juat used it and not had shorts or anything with exposed bladeS?
Old 11-23-2009, 02:54 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
That's crazy looking. The one I got looked like the one that it replaced. 2 connectors.
Beat it to fit,
Old 11-23-2009, 06:48 PM   #12
vegaschevy
Hell I even thought Being Napa that it might be a hair better then the others. LOL
Old 11-23-2009, 10:17 PM   #13
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The 1 I bought from NAPA looked just like the old 1 I removed. I don't think you got the right 1.
