Wiring issue
I know this is a LOOOONG shot but ill explain the issue and maybe just maybe somebody will have had this problem before.
New Rebel Wire 9+3 circuit kit. Everything is connected and working other than taillights working strangely. The right hand tail light flashes on both directional signals. Brake lights are on all the time and regular tail lights work. When i put pressure on the brake..The whole cluster flashes on the signal flasher?!?! so obviously something is wrong between the brakes and tail lights. When i disconnect the brake light the right signal still flashes both ways. Also should not that the front flashes work correctly other than the left flasher works key on or off and the right flasher only works with the key on. Very confusing. ![]() Jory ![]() Any help advise or suggestions would be very much appreciated! |
Re: Wiring issue
sounds like multible issues to me is it a double flasher unit or a single?
Re: Wiring issue
Re: Wiring issue
from the two flashers you should have like 6 wires correct?
Re: Wiring issue
to the column yes...
Jory |
Re: Wiring issue
that will be 2 to the rear 2 to the front and 2 power.also do you have a wiring diagram for your truck?
