11-26-2009, 02:02 PM | #1 |
Timing Light
Please pardon my ignorance on this subject. I have an old Sun timing light that works just great. But, I just picked up a Snap-On ADVANCE timing light. My problem is, I have no clue how to use the advance, nor what it's purpose is! I got it at the flea market, and there's no instructions. I looked online but I could not find any instructions, or how-to there either. Any help?
A man's thoughts devise his ways; but it's GOD that directs his steps. |
11-26-2009, 04:22 PM | #2 |
Re: Timing Light
We used that light with the wheel to check timing advance on Caterpillar 3208 diesel engines
11-26-2009, 04:46 PM | #3 |
Re: Timing Light
The advance knob on the advance light is used to check the total timing at higher rpm. Say your engine was supposed to have 38 degrees of total timing at 3600 rpm you would set the knob on 38 and then run the engine up to 3600 rpm and check the timing and the marks should line up at "0". You can also do it in reverse and run the engine up to X# of rpm and while pointing the light at the timing marks turn the knob so that it shows the marks lined up at 0 then read what the pointer on the knob is pointing at and you have the total timing at that rpm.
For engines that are hard to read the timing tags on I set my light on the degrees that I want to set the initial timing on and then all I have to do is line up the 0 on the tab with the line on the damper. That is what about 90% of the guys use them for. Or you can set the knob on 0 and use it like any regular timing light. |
11-26-2009, 04:51 PM | #4 |
I am a Referee of life.
Re: Timing Light
I always use a paint pen and mark the 0* mark on the pointer.This makes it easier to see the marks.I usually use a Black "Sharpie" to mark the balancer also.Just makes it easier to see things.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-27-2009, 10:08 AM | #5 |
70 Chevy 3/4t
Re: Timing Light
I like to use a piece of the kids sidewalk chalk to help illuminate the markings on the balancer and timing mark. You dont have to be so accurate and you can smear it into the grooves with your finger seeing numbers and marks.
Find a job you love and you'll never have to work a day in your life. 1998 Yamaha V-Star 650 1970 Chevy 3/4t, I6 (rebuilt), 4 speed Kokomo,IN |
11-26-2009, 06:16 PM | #6 |
Re: Timing Light
That timing light might give you a wrong reading if you are running MSD stuff.
11-27-2009, 06:25 AM | #7 |
Re: Timing Light
OK........Now I understand. Thanks all.
11-27-2009, 09:36 AM | #8 |
Re: Timing Light
Why? Any particular MSD components or combinations?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
