is cutting 2 drop coils a bad idea?
i have 2 inch drop coils and 2.5 inch spindles, i want to go lower. would cutting the springs be bad?
thanks, david |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: is cutting 2 drop coils a bad idea?
1/2 coil will get you approximately 1 inch of drop.
So cut carefully.
#4 | |
You have a set of 2" drop springs. Correct? How much lower do you want them? Cut a half coil. That will get you a 3" total drop. I wouldn't cut more than a half coil.
Cut only the bottom of the spring.
(look at the red cut line)
so where the spring stops, i cut the exact same spot on the other side of it? doi i cut the top or the bottom?
#7 | ||
You'll need to get the front re-aligned by someone that understands lowered vehicles. Shops that don't do 'dropped' vehicles will typically say it can't be aligned if it's dropped..... we all know they can. BTW.... more than 1/2 a coil off those shorter springs & they'll come loose anytime the front suspension is extended. They can (& possibly will) fall out if they come loose.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-28-2009 at 12:33 AM. |
Edit:
Scoti,... you type faster than me. Anytime you shorten the front springs, you will affect the camber. I suggest getting the front end aligned when you are done. I also suggest using a good quality drop shock.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-28-2009 at 12:34 AM. |
thanks guys, will i be fine if i only cut 1/2 coil off? or will it fall out?
i have brand new nitro drop 2 on already. and by 1/2 coil u mean that after i make the cut, the piece i cut off will look like a "c" right? thanks Last edited by dbmx66; 11-28-2009 at 12:40 AM. |
#12 | ||
also, will it ride like crap if i cut 1/2 coil off?
It will ride the same as a 3" drop coil. Does it ride like crap now?
Full coil = O 1/2 coil = C Post up some pics of your truck.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-28-2009 at 12:51 AM. |
#15 | |
last time i drove it had stock suspension. its been my project for a while now. i dont have many good pics. they were takin months ago heres one with 4.5/6 drop. how much will it drop when the motor/ front clip are on? ![]() ![]() Last edited by dbmx66; 11-28-2009 at 01:00 AM. |
#16 |
OK.
Don't do anything until it's back together and on the road.
#17 |
do u know how much it will drop down the front after the motor and front clip are on?
#18 |
Can you take a picture of your front suspension already on the truck? (front the front side of the a-arm).
#19 |
Spring might be a little loose in the spring pocket only when the truck is off the ground and the a-arm is hanging all the way down.
#20 |
Do you still have the rubber bumpstops installed up front?
#21 |
How tall of tire do you have up front?
Do you have room to drop it another inch and still have clearance at the fenderwell and the inner fender?
#22 |
no.
sorry. I think you are getting the "cart before the horse".
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-28-2009 at 01:09 AM. |
#23 | |
high-Tech Red Neck
It isnt that hard to pull a spring once the truck is assembeled, save it for last, this way you are sure to achieve the look you want with out having to buy springs twice.
"He used to be a pretty nice feller, now he's a welder!" |
#24 |
that makes sense, thanks for the help.
i could always get it lower in the front with smaller tires couldnt i? |
#25 | |
high-Tech Red Neck
