11-29-2009, 12:12 PM | #1 |
Carb issues - accelerator pump?
So, I get some backfiring when I try to gve it more throttle quickly. It also helps if I pump the gas pedal progressively as I'm giving it more gas (like stairs). how would I confirm that it is the accel pump and not a vac leak? How do I cnfirm my carb? It is a California 72 with 350v8... Also, how do icheck if it is a th400 vs th350 turbo- hydromatic?
Zach |
11-29-2009, 12:28 PM | #2 |
Between Trucks...
Re: Carb issues - accelerator pump?
Can't help with the carb issue, but you can I.D. the transmission by the shape of the pan. http://www.nastyz28.com/chevy-transm...tification.php
Beat it to fit, Paint it to match... |
11-29-2009, 01:18 PM | #3 |
Active Member
You can give the accelerator pump a quick visual check with a small flashlight.
Take the breather off the carb, run the truck for a minute or so -running it will insure you have a full bowl and the gas hasn't leaked out -then look in the throat as you manually move the throttle. You should see a good stream of gas squirting out. If it's real weak or if you don't see any, then the pump is supect or the float adjustment. |
11-29-2009, 03:23 PM | #4 |
maybe you got junk in the float bowl? are u still runnin points?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
11-29-2009, 03:24 PM | #5 |
my truc kwasnt running right so i wiggled the float and it solved that problem
