Going to do the 5.3 swap
Going to pull my existing motor out and replace it with an 02` 5.3L with computer. Any of you guys that have done it or are doing it what am I in for ??
Re: Going to do the 5.3 swap
I want to do the same keep me posted on your updates.
![]() Join Date: Apr 2005
I have one in my 69 Burb and my 67 Crewcab. You can check both of my builds in my signature.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Mine (6.0/4l80) is in daily driver mode!!
Link in sig!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
What do you guys do about wiring? Painless? Stock gauges? Stock key switch? I'm using an LT1/4L60E and those are my hold ups.
![]() Join Date: Aug 2004
From everything I have heard, Nelson Performance is the way to go. They custom make the engine harness, I wish I would have went that way, just because the cheaper way isnt always a better way. Look at LS1Truck, LS1tech for more information. You can go with Wait4me performance, inexpensive but not pretty. If you go the latter way, PM me so I can tell you what to have them remove. It will make for a cleaner install. You can also do the harness yourself, look at LS1Swap.com.
More food for thought. As far as the key switch and all that, stock is fine. however with the 4l60e, you will either need to change the tailhousing for a cable type or buy a digital speedo. if you are rebuilding the trans, go with the tail shaft. or you can just go with a 700r4.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 12-01-2009 at 05:12 PM. Reason: adding more info and again |
#7 | ||
I am using the stock gauges. Quote:
Stock key switch. LT1/4l60e: have you looked at the EFIConnection 24x set up? it sets up the harness to use the LS1 PCM, coils, etc. $1800 for everything and they have lower cost options. The benefits is no more opti and the tuning ability is way better with the LSx PCM, and not limited to 7k RPM limit like the LT1 pcm if you need to spin the motor that high.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 12-01-2009 at 05:27 PM. |
Im not building anything to extravigant, I just didn't know how all the wiring ties into the truck. When i get to that point i'll decide, for now i have the engine, tranny, stock LT1 wiring. I'm going to yank the nose and cab soon and start the frame work, get mounts and tranny mounts and go from there.
Thank you all for the info. |
Shon,
What is the cable X box?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
With the engine mounts and trans cross member of your choice it fits right in there. With alittle time, patience and research the wiring can easily be done by yourself. I fallowed alot of "68 short step's" threads to get most of my info.. There is alot info and other threads on here that will help you get it done and if not, just ask. Somebody will be happy to help.
Trevor
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
Abbot Cable X
here is there website: http://www.atrol.com/cablex.htm If anyone needs one contact me for pricing.
![]() Join Date: Nov 2008
you can read the last 2 pages of my 68 build thread. I answered a lot of these questions in there.
Hope to fire my 5.3L up tomorrow! |
I will ship them for $300.
#15 |
Well, dummy me, I didnt ask here before I bought a new speedo, I will probably do it when I do my dad's 6.0 for sure.
I appreciate it, very good price too!
#16 |
I like the box b/c it allows the retentioin of the stock speedo/odo.
for me that was the selling point. very proud of it only having 109k miles on it. Setting up the dip switches is EASY if using the VSS output from the PCM that would normally run the speedo in original vehicle.
#17 |
Yes that is how my digital speedo hooks to the trans. NUTS!
#18 |
the boat guy
its not hard to get $1000 into the fuel system.
im using wait4me harness, everybody says it looks great? original switch and guages, trying to put an s-10 speedo behing stock speedo.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#19 |
bbadfred
![]() Join Date: Mar 2008
Call John Spear at speartech. He will answer all your questions and either redo your harness or build you a stand alone engine trans harness and reprogram the stock computer. speartech.com in Anderson Indiana.
#20 |
$450 to take a stock harness and do it up.
