01-22-2003, 06:35 PM | #1 |
who do i want to order my c-notch from??
i brought up this question a while back and forgot the answer...
which c-notch doesnt interfere with (or doesnt interfere as much as the other brands) the adjustable tracking arms? also did anyone find a c-notch and adj tracking arm that wont interfere with each other when you get real low? got my por15 and degreaser here, beds off, springs are out, time for me to notch the frame, paint it and get my bags in.. so i need to order that notch ASAP. |
01-22-2003, 06:46 PM | #2 |
Progress = 0%
The Classic Performance Products C-notch will interfere with the Early Classics modified panhard bar. See pic below.
And here is how I fixed it.....
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
01-22-2003, 06:51 PM | #3 |
so it orginally mounted under the axle on top of the arm and you just cut the mount down and welded it down into the side of the arm?
01-22-2003, 06:55 PM | #4 |
Progress = 0%
Yep! The kit comes with the bracket that fits between the arm and the axle pads. It also comes with a spacer plate for the other side so they are the same. I just hacked off the part of the bracket that the rod mounts to and welded it to the inside of the trailing arm.
01-22-2003, 06:55 PM | #5 |
oh yea nother question slammed, your pumpkin doesnt hit the bed floor with the axle bottomed on the c-notch does it?
01-22-2003, 08:09 PM | #6 |
L.E.D. Freak
My question is the C-notch kit from Classic Performance Products the only kit out there bolt on? And is it a true bolt on aplication or do you recommend welding it also? I'm thinking of getting it soon, along with a bolt on hidden hitch.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
01-22-2003, 08:58 PM | #7 | ||
Seņor Member
I hope this helps, Kenneth
01-22-2003, 09:40 PM | #8 |
build your own! you would be suprised how easy it is if you have a welder, grinder, and a torch. I built my own out of 1/4 inch stock using a piece of cardboard as a template.Cut the frame notch out with a sawzall to reduce heating the frame up.
'72 1/2 ton short box 468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition turbo 400 tci. 2800 verter ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears custom built rear frame tubbed, 33/19.50/15 rear m/t. m/t skinnies in front still under construction |
01-22-2003, 10:48 PM | #9 | |
01-23-2003, 12:12 AM | #10 |
Progress = 0%
XXL is correct. The pumkin will hit the floor without the snubbers. I resolved this issue my raising my bed floor 1.5". Mine is a steel floor, but I'm sure a wood bed would be done in the same manner.
01-23-2003, 09:05 AM | #11 | |
Seņor Member
Kenneth
01-23-2003, 09:07 AM | #12 | |
Seņor Member
Kenneth
01-23-2003, 01:34 PM | #13 |
Slammed67 how much drop do you have and what kind? I just bought a ECE 4/6 kit but havent installed it yet. I was considering a C-notch to allow me to go lower later (I have the frame stripped at the moment). I wasnt aware of the problem with the track bar. Do you know how much clearance would be between the frame and axle with the ECE 4/6 kit or how much lower I can go with the track bar becoming a problem with or without a C-notch?
Mark 72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction 05' GMC Sierra Denali LQ9 |
01-23-2003, 02:56 PM | #14 |
Progress = 0%
GMCGRANDS: My truck has air bags. I'd think with the 4x6 drop, you'd be okay with the c-notch since you'd probably leave the rubber snubbers in place.
XXL: I actually raised the stock floor. I've got some pics at home that I can send you. (I'm at work now) It was pretty easy to do. I wasn't about to put a big "hump" in my floor or cut out a hole for the pumkin.
01-23-2003, 03:21 PM | #15 | ||
Seņor Member
Kenneth
