Old 01-22-2003, 09:31 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
What rear end gear do I have???
I recently put a tach in my truck and went out on the high way and got some RPM data. then I went to smokemup.com and tried to figure my rear end with my tires and what not. It said I had something like a 4.56...is this possible and how can I verify this? Sould I drop down to a 4.10 or something? I thought I had 4.10s but maybe I dont. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-22-2003, 11:22 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
I can't recall the exact ratio number, but 4.56 was an option on the 3/4 ton trucks. Unless you're pulling loads all the time, I'd go for a 3.73, possibly even the 3.42. Both are available in the 14 bolt full floater, 3.73s are easier to find. $300 in the yards around here.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-23-2003, 12:11 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Bummer is though, he probably does have a 4.56 gear, and it is probably in the Eaton/Corp rear axle which is very expensive to find gears for.
Old 01-23-2003, 02:15 AM   #4
HotRod929
HotRod929's Avatar
Is there any way for me to deffinatly tell if I have the old Eaton/Corp rear axle and if I have 4.56 grears? If I post a pick of the rear end can you tell if its and Eaton or not? My friend thats into Caprices said I had a 10 bolt but i dunno. Let me know please. Thanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-23-2003, 02:23 AM   #5
HotRod929
HotRod929's Avatar
Also if I do have and Eaton/Corp axle is it worth anything? Will I be able to make some money by selling it and getting another rear axle? If I do get a new rear axle what would you guys recomend and what would be the easyest to swap in? Thanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-23-2003, 11:50 AM   #6
HotRod929
HotRod929's Avatar
anyone???
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-23-2003, 01:53 PM   #7
lukecp
Formerly yellow72custom
lukecp's Avatar
To find out your gear ratio, pop off the rearend cover, and divide the number of teeth on the ring gear by the number of teeth on the pinion gear. The fluid proably needs to be changed anyway.
BTW, i'm pretty sure that on the 350 powered 3/4 ton trucks, 4.10 gears came standard. The 307 and 6-cyl trucks came with 4.56 gears. 4.56 were optional though, and your rear axle might have been swapped out sometime in the past.
The 402 big block 3/4 ton trucks usually had a 3.54 gear ratio, which would be much, much better for highway driving.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-23-2003, 09:33 PM   #8
MAC67
" SHOW ME"
MAC67's Avatar
to tell the differance between the eatons and the 14 bolt corp,,is pretty easy if im not mistaken,,the eaton will look like a ford nine inch on steroids,,it has a removable rear diff cover and a drop out third member from the front,,,youre 14 bolt will have 14 bolts holdin the rear diff cover on,,,the eatons have a smooth flowing lines where youre center meets the axle tubes,,,and a 14 bolts tubes are pressed into the centers
MAC67 is offline   Reply With Quote
Old 01-24-2003, 02:17 AM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Here's a shot of a 14 bolt corporate.
Fred
Old 01-24-2003, 03:15 AM   #10
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Eatons have a perfectly round rear cover, and the unit does drop out from the front, and only 4.10 and 4.56 were installed in chevy trucks.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 01-25-2003, 06:23 PM   #11
casey
casey's Avatar
Put some 20" rims on her will that work, Might change you ratio enough to live with and would look real cool
casey is offline   Reply With Quote
Old 01-26-2003, 09:36 PM   #12
rustedchevy
actual tire dimaeter hieght changes affect rpm at a given speed
4.56 was std ratio for dana 60 equipped trucks
4.10 was optional for dana 60 and eaton
and 3.54 weas optional in dana 60
4.57 is std in eaton, if its eato then its 4.57 or 4.10
rustedchevy is offline   Reply With Quote
Old 01-26-2003, 09:47 PM   #13
mikep
Used to have a truck
mikep's Avatar
3.54 was standard ratio for big block equipped dana 60's like mine...
mine has coil springs. Yours doesnt ?
No truck :-(
mikep is offline   Reply With Quote
