Old 12-07-2009, 04:56 PM   #1
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
brake upgrade question......
Hello all,
I have recently performed the crossmember and rear end swap on my 61 with a 78 Chevy. The only master cylinder I had was from a early 90's s-10 (no booster). Its all finished and brakes properly bled, but I seem to be experiencing a "long" pedal. The truck stops, but not until the pedal is almost to the floor. Is an s-10 master too small of a bore? Btw, I am running the s-10 proportioning valve as well.
Any suggestions would be apprieciated.
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 12-07-2009, 05:31 PM   #2
jgarverick
Re: brake upgrade question......
i'm thinking the bore is probably too small. 78 master lists a bore of 1 1/8 in and 90 s-10 as 30 and 36 mm which i think is a dual bore size for front and rear division. anyone else have something?
Jason Garverick
64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread
69 AMC Javelin 360/auto - 417 stroker (soon)
68 Scout (Basketcase)
06 Ram HEMI SWB Reg Cab Daily Driver
US Army Vet
jgarverick is offline   Reply With Quote
Old 12-07-2009, 05:35 PM   #3
jgarverick
actually 30 mm is 1.1811 in so maybe not... maybe theres a mechanical difference designed into the pedal assembly?
Jason Garverick
US Army Vet
Old 12-08-2009, 01:03 AM   #4
Captainfab
60-66 Nut
Are you running a power brake master without a power booster?
Old 12-08-2009, 02:04 AM   #5
overtimeracing
overtimeracing's Avatar
http://www.summitracing.com/parts/WIL-260-1874/
Does it feel like you need to pump the brakes? Like a soft pedal? Im running these on my 68 Amc Javelin. I have manual disk brakes front and back. They help firm up the pedal. They make these for disk and drum brakes.
overtimeracing is offline   Reply With Quote
Old 12-08-2009, 03:02 PM   #6
Eagletucky
Eagletucky's Avatar
Yes, is that where I goofed up?
I was under the impression it didnt matter.
Old 12-08-2009, 04:57 PM   #7
62gmc910
62gmc910's Avatar
I run a 78 gmc c20 master with manual pedal and heavey 3/4 ton brakes , with the 78 proportioning valve with very little pedal travel ' just need lots of force,
The S trucks had small front calipers so it could be a volume issue.
Captainfab makes a real nice bracket to adapt a power booster if you dont need clutch master clearance Also check to see of your rear shoes are set up tight enough,IE that the self adjusters are working
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-09-2009, 02:20 AM   #8
Captainfab
60-66 Nut
I was under the impression that it did matter. I've not tried it, so I can't say from experience. Although it seems that 62gmc910 has done this sucessfully, but with a C20 master on C20 brakes. So the master may be the difference. There were manual brakes available in the C10's up thru the mid 70's somewhere.
Old 12-09-2009, 10:19 AM   #9
Eagletucky
Eagletucky's Avatar
I think I will try a manual C-10 master. I'll let you know how that goes!
Thanks guys!
Old 12-08-2009, 05:31 PM   #10
jgarverick
sounds like the bore isn't the problem. maybe the mc just doesn't have enough bore length to pressurize the calipers sufficiently.
Jason Garverick
US Army Vet
Old 12-09-2009, 06:47 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
I also think the problem is in the compatibility of the m/c. I had a somewhat reverse problem years ago on a 67 Chevelle I switched to discs on the front. I don't remember the details but used the booster from either a non-disc setup, or the wrong application. There was no modulation in the pedal at all. The slightest touch of the pedal locked the brakes. My test run couldn't even get down the block, before I drove home using the emergency brake. The problem was a mismatch between the depth of the back of the master cylinder and the length of the push rod sticking out the front of the booster. I realize you aren't running a booster, just pointing out some of these dimensions are critical.
I ran manual discs on the front of my 1960 for several years using a 1975 C10 disc brake m/c and it worked fine other than requiring a lot of foot pressure. Back problems finally convinced me to install a booster.
Old 12-10-2009, 05:59 PM   #12
TimE
Hey Y'all!!
TimE's Avatar
Thanks for the clarification 68 TT!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
