Arizona Emissions
Hi
I have a friend with a 85 chevy truck that will not pass emissions. He has the queadrajet with the computer. Can we swap it out to a new carb edelbrock/holley? We would like to eliminate alot of the vacuum assy under the hood at the same time but we do not know what Az emissions looks at. |
Re: Arizona Emissions
You need to find out what the state requires. Some look for any changes or disconnected hoses and flunk you outright. Overly advanced timing will ruin emissions at idle. Most sniff for excessive hydrocarbons etc. in the tailpipe. Retarded timing at idle helps keep these things down, but the truck will run like crap. I once had a modified van with dual carbs, a 3/4 cam, headers and full centrifugal distributor. It failed emissions until I retarded the timing to minus 5 degrees at idle, and jacked up the carbs speed so it would run ( barely). It then passed, but wouldn't beat a baby carriage in a downhill race until I readjusted it. My Corvette passed because it was too low to put on the rollers. Go figure. It's just tree-hugger insanity and it's going to get worse with the crew we got in at the top.
#3 | |
Gettin It One Pice At A Time
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
Redefining LowBudget
try this trick it has never let me down go to home cheapo or something and get 3 or 4 gallons of wood grain alchol run the tank down pour it in disconect the vacum advance and run it though.....after you leave hit it with some marvel mystry and then go top it off..that should get you though
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
