Rim back spacing?
Stock 12bolt under 71 LWB with Drum brakes.
what BS will work? Will a Weld ProStar 15x10 7.5BS with a 275/60/15 Hoosier DR work? I probably will have to get an adaptor since i have 5x5 and the rims are 5x4.75. I want to see what the truck will do with the 6.0 in it and I know the street tires have no chance....truck is not set up to DR that is for sure so it should be hilarious!!!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
Re: Rim back spacing?
My truck is a 82, so it might be different. I used a 15X10 with 4.5BS and it put the tire just inside the fender lip and left me several inches on the inside of the tire. I would think 7.5BS would tuck that rim pretty deep and close to the frame. Right?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
got someone else wanting to get rid of some 15x8 Telstars with 4.5" BS and 5x5 botl pattern. will these work?
I am guessing that if I get this thing on track then I will eventually want the 15x10s so I can get a tire back there for traction.
15x10 with 4.5 to a 5.5" of backspacing looks pretty good. i also believe a 7.5" would be to much for a 10" rim, but perfect for a 12" rim... the telestars will work..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
![]() Join Date: Apr 2005
I've got 15 X 12 with a 6" backspacing (wide rearend).
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
It sounds like maybe you could run a 2" spacer/adapter and come out with the correct fit. But I'm not sure how safe that is. I know a guy on another forum that did that with some 4-3/4 wheels on his fullsize. He raced with them and everything(I believe it was an 11sec truck). He told me to just make sure I buy quality spacers/adapters and inspect them constantly. But I don't remember who makes the adapters he used.
Redefining LowBudget
Hart Rod (Rob) I love your truck!!...where is Pace I goto Fla quiete a bit I would love to touch it...lol
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
It's about 15 miles NE of Pensacola. LMK.
