Location: Where I come from, it's cornbread and chicken...
want opinions and pics
I'm thinking about maybe taking my truck and putting a cab and chassis rear under it and putting some 19.5s on it and lowering it down some...I like the look of dually wheels, but I don't think a regular cab swb dually would look good with the fenders on the bed and the truck being so short...so I thought maybe get a cab and chassis rear and tuck the wheels up under the fleetside bed sides...just a thought...what do yall think...
Chuck. |
HORSEPOWER JUNKIE
Re: want opinions and pics
I've seen pictures of a fleetside with that set up with standard off set dually rims the tires only come out of the fenders about an 1 in 1.5 in it didnt look bad at all some small flares and your all set
67 C20 fleetside custom camper 69 El Camino 72 Camaro 52 Dodge b3b 108 pickup |
I'd rather shorten the axles and have all of the wheel/tire up under the bed...
you will have too.
get a you 14bff and find a second short shaft and knock the differance out of the longshaft tube, install short shaft and you are now atleast 3" narrower. |
HORSEPOWER JUNKIE
found the pic
and then it'll fit up under the bed right? do you think I should just extend the wheel wells out like factory...I'd like to do this for the look, because I don't think I'll ever tow a fifth wheel trailer or anything, I don't even know if my 6.2 would tow it...I just thought it would be cool to see...
see now if I could get the wheels under the bed like 2tons of fun said, then I'd be in business...I also think I'm going to put cab lights up on the roof whether I put drw axle under it or not...
HORSEPOWER JUNKIE
you will have to relocate the leaf springs a cab chassis axle has the tires real close too the leafs
that's no problem...shortening the axle is what worries me
HORSEPOWER JUNKIE
thats not a problem they do that for drag cars and crawlers all the time!
is shortening the housing and putting a shortside shaft in the longside doable by me or do I need to take it to a specialist?
HORSEPOWER JUNKIE
that depends on your welding skills how well can you weld .500 wall tube?
I have a good friend of mine that can weld it...is it just a matter of measuring the axle tube, welding it and then sliding a shortside shaft in there or does the shaft need to be shortened as well?
HORSEPOWER JUNKIE
that depends on how much you shorten it but yes you can install a short shaft in there with out a problem just like 2 ton of fun said!
