12-15-2009, 11:37 PM | #1 |
Luv the Crewcabs
Will a 5 Speed that came in 81 fullsize Fit to a 6.2 Diesel?
I have this overdrive Tranny that was original to a 81 Fullsize Chevy Truck, Trying to Sell it on my Local CL & Got an Inquiry if it would work with a 6.2 Diesel Engine ???
Was a 6 cyl Truck if that would matter, What do u Guy's Think? Will it work for his 6.2? Thanks for any Info ........... Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
12-15-2009, 11:50 PM | #2 |
huh ???
Re: Will a 5 Speed that came in 81 fullsize Fit to a 6.2 Diesel?
That pic of the shift knob is only a 4 spd...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
12-16-2009, 12:06 AM | #3 |
Luv the Crewcabs
Take a Closer look at Middle Pic, Shows 4th has OD......
I drove the Truck Till Motor went Klaplueeeeeeee WAs Nice having a 5 Speed....... thirdstreettito, I knew you would Prolly know the answer & Almost just pm-ed you about it. Then i thought that the knowledge would be Good for the Board & Posted it ....... Thanks, Rick
12-16-2009, 01:29 AM | #4 |
how is it a 5speed again???
1 2 3 od, it r 4spd. |
12-16-2009, 01:45 AM | #5 | |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-16-2009, 08:29 AM | #6 |
6977chev-Please don't turn this in to a "For Sale" post.
12-16-2009, 12:00 AM | #7 |
Resident of Here
Yeah, its a 4-speed OD. With the right bellhousing and input shaft it should work. Call Advanced Adapters after you get numbers off the tranny. Tell em the number, they should be able to hook you up, or know who can hook you up. No pun intended.
12-16-2009, 12:04 AM | #8 |
Professional Grade
Yup, it'll bolt right on and use the same clutch as an SM465 equipped 6.2L would (factory trans used behind the diesels).
However, I doubt that one of those little A883s would be up to handling the torque generated by anything bigger than the 305 it was probably behind from the factory
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-16-2009, 01:27 AM | #9 | |
Moderator
The A833 countershafts can and do spin and wallow out the case behind the bellhousing. If it leaks oil from the countershaft bore you'll need to bore and bush the case. |
12-16-2009, 09:40 AM | #10 | |
Professional Grade
12-16-2009, 09:55 AM | #11 |
Insert Witty Text Here
Here is some good info on them:
http://www.customclassictrucks.com/t...ion/index.html I agree that it is a 4 speed, not a 5 speed. Slonaker |
12-16-2009, 07:46 PM | #12 |
I looked at a 82 1/2 ton 4x4 last year that had that trans behind a 6.2 from the factory. I was going to buy it and put another body on it because it had been rolled. The old guy who owned it had owned it since 1984 and said that truck would get 22mpg. I really wanted to buy it but he wanted WAY to much for a truck that was going to need a total body swap.
12-16-2009, 11:46 PM | #13 |
huh ???
Found this on the net.
"The Overdrive four speed was a regular A-833 with an overdriven gear set installed in place of the regular third gear. The shift lever on the side cover was flipped over to "fool" the shifter into shifting from second to fourth and then back into third, which was the overdrive gear. The overdrive gear is very small and as a result, the mainshaft journal and splined hub is smaller. You can swap OD 833 parts as a set into the correct case for the mainshaft."
12-17-2009, 01:55 AM | #14 | |
Location: Where I come from, it's cornbread and chicken...
12-17-2009, 02:11 AM | #15 |
its still a 4spd,
you have to flip a lever on the side cover, are you going to do that at speed? when the lever is flipped it swap the shift pattern in a way that doesnt make sence but is not something that i would think is possible to do while driving. |
12-16-2009, 11:51 PM | #16 |
4 forward gears and 1 reverse = 5 gears...
don't you guys know anything... |
12-17-2009, 01:22 AM | #17 |
btw Rick, just to clarify, I was kidding....not trying to rattle any chains...just a joke...I know that wasn't directed toward me, but thought I would clarify...
12-17-2009, 01:32 AM | #18 | |
Luv the Crewcabs
Just kinda Upsets me when Stuff like this Happens, I Don't expect to see this Here. I feel that for the most Part members here are Above this petty Bickering........... Any more of it & I will ask that the Thread be deleted, In that case we alll lose as some Good info was Posted. Thanks, Rick
12-17-2009, 01:35 AM | #19 |
yeah like I said, I'm sorry for it...I kinda got carried away with the joking around and thought I'd add my 2 cents...
12-17-2009, 01:48 AM | #20 |
Rick, not to beat a dead horse, but I don't understand how it is a 5 speed?
First, second, third, and overdrive is 4 speeds, where does the fifth gear come in? Does it have a solenoid in the trans to engage overdrive? Seems like this would be a cool trans in a daily driver for some decent mileage.....
CHEVY ONLY Last edited by joe231; 12-17-2009 at 01:50 AM. |
12-17-2009, 02:14 AM | #21 |
either way, it does still have 5 forward gear speeds...
it's really starting to split hairs now...he only asked if it would fit behind a 6.2...that question has already been answered... now it's just arguing to argue...I'm done with it... |
12-17-2009, 03:36 AM | #22 |
Luv the Crewcabs
Could a Mod Please Just Lock this Thread , Apparently owning, Driving, shifting this Transmission is not enough Proof that it Has 5 forward Gears.......
Rick
12-17-2009, 09:21 AM | #23 |
I don't understand why everyone is getting bent out of shape?
Rick, I'm not doubting you, I'm just trying to understand how it has 5 speeds when the shifter knob, and the link posted with info about it, only shows 4 forward gears. The text Fat Hoe quoted only describes how the shifter is set up to work, it doesn't explain how there are 5 forward gears.... It basically says that 3rd and 4th gear are flip flopped and what was 4th gear(1:1 ratio) becomes 3rd, and what was 3rd becomes OD(with a new gear set of .73:1)
CHEVY ONLY Last edited by joe231; 12-17-2009 at 09:27 AM. |
