Indicator bulb wire color
What color is the wire to the left turn signal indicator bulb in the instrument panel? I've got two bulbs hanging under the dash and neither work, both with new bulbs.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson |
Re: Indicator bulb wire color
You might do a search on this forum or jump over to the electrical one. I've seen the wiring diagram on here several times. I do know the dash lights are all grey wires.
Members i've met: LiLRed66 |
Dude, I always search first. Couldn't find anything, that's why I asked. Anyone else know the color?
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson Last edited by Sicboy; 12-17-2009 at 08:28 PM. |
HOW long until spring??
![]() Join Date: Mar 2009
If they are just hanging loose, try grounding them to frame.
Right Hand is dark blue-----left hand is light blue at dash lights Found this in a 64 supplement to factory gm manual
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Thanks. Yea, I replaced both bulbs and tried grounding to the frame and plugging into dash socket, but nothing.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson Last edited by Sicboy; 12-17-2009 at 10:11 PM. |
They will not come on unless the ignition switch is on and the turn signal lever is in the proper position. They should then blink, when the socket is grounded against the back of the gauge cluster. Also, check the flasher plugged into the fuse block, as well as the fuse.
#7 | |
Right indicator works, left does not, all turn signals work, flasher works, fuses good. Must be a wiring problem. I just needed to know which color wire was the left indicator. Thanks again Bubba.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson Last edited by Sicboy; 12-18-2009 at 01:50 AM. |
![]() Join Date: Oct 2006
maybe this will help you out
http://www.6066gmcguy.org/turnlights1.htm but now you know the color try using a test light to check the non working lead.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
