12-17-2009, 12:15 PM | #1 |
2 1/8" Primary Headers
Please help me source some 2 1/8" primary headers for my 69 with 74 bbc engine mounts. The AFR315 fully ported heads need to breath. Thanks.
12-17-2009, 12:45 PM | #2 |
Re: 2 1/8" Primary Headers
i don't think they make an off the shelf header for our trucks in 2 1/8
12-17-2009, 02:18 PM | #3 |
Hooker Comp for Chevelle is 2in primaries and 3 1/2 in collector and fits our trucks sliding inside the frame rails. Should be fine unless you have crazy HP 800+..
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. Last edited by ripdog28; 12-17-2009 at 02:18 PM. |
12-17-2009, 02:30 PM | #4 |
see if you can use anything from here
http://www.lemonsheaders.com/products/bbr-545.htm or http://www.lemonsheaders.com/products/bbpt-610-615.htm look at this http://speedtalk.com/forum/viewtopic...0a26c79bbfef7a
nickle and dime Last edited by royo; 12-17-2009 at 02:45 PM. |
12-17-2009, 08:04 PM | #5 |
I have the hooker supercomps with a 2" primary and a 3.5" collector and are equal length, they fit pretty good for an equal length and they flow good...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
12-18-2009, 08:29 PM | #6 |
Has anyone had success or disaster with these in a 67-72 bbc 2wd, bb engine stands, with standard components up front? My preference is the first one.
Hooker Super Comp 2220HKR http://www.summitracing.com/parts/HOK-2220HKR/ 2265HKR Black http://www.summitracing.com/parts/HOK-2265HKR/ 2265-1HKR Ceramic Coated http://www.summitracing.com/parts/HOK-2265-1HKR/ You guys can debate the 2 vs 2 1/8 advantages, but I am past that. Both AFR and Dynomation indicate the 2 1/8 for my setup, and will be implementing N2O on top of that. Dont get me wrong, good discussion, but I'm stuck with a build in SD and a fab shop in CA right now. Thanks. Last edited by gene_ensor; 12-18-2009 at 09:06 PM. |
01-09-2010, 01:58 PM | #7 |
mt
01-09-2010, 02:05 PM | #8 | |
and does the collector hang down like right bellow the bottom frame rail where you would have enough room to bolt mufflers directy to them i have a very similar setup 72c10 big block and same heads and i came up with chevelle headers would be the cheapest way to get somthing bigger than a 1.75 " primary |
01-09-2010, 02:45 PM | #9 |
To the O.P.,
you may try calling Tom Dawson Racing Headers. About 15 years ago, I had them make a set of 1 7/8 x 3 1/2 custom headers for my '66 with a sbc, and the headers fit like a glove. Tom used to be an engineer for Hooker and he would take a set of headers for a specific application, set them up in a jig, and duplicate those headers in whatever size pipe you want. I have nothing but good to say about them. Their shop is located in Nuevo, Ca. and their number is 951-928-0969. Good luck with your build!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
12-19-2009, 06:27 PM | #10 |
At the body shop.
Air male posted before that chevelle 2 1/8 headers work. Ill see if i can find the post. My mistake 2" sorry
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 12-19-2009 at 06:37 PM. |
01-13-2010, 10:26 AM | #11 |
Hooker makes Super Comps for 73-87 trucks with 2" primaries, would that work for you?
01-13-2010, 10:29 AM | #12 |
http://www.holley.com/types/Super%20...WD%20Truck.asp
2841-1HKR 68–87 Chevy/GMC 1/2, 3/4 & 1–Ton Truck, 68–91 Blazer/Yukon/Jimmy/Suburban/1–Ton Crew Cab: 396–502 Full Length Header Tube Size 2" x 35", Collector Size 3.5", Collector Length 10", Port Shape: Same As Port, Metallic Ceramic Coating 2841HKR 68–87 Chevy/GMC 1/2, 3/4 & 1–Ton Truck, 68–91 Blazer/Yukon/Jimmy/Suburban/1–Ton Crew Cab: 396–502 Full Length Header Tube Size 2" x 35", Collector Size 3.5", Collector Length 10", Port Shape: Same As Port, Black High temp paint |
01-14-2010, 07:36 PM | #13 |
the problem with the headers "DESIGNED" for these trucks is that they hang down very low. The hooker #2455 work for me in a slammed 2wd auto with b&m shifter. 2" primary should be more than most need in a header, for everyone else $$$custom$$$
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction Last edited by AirMale; 01-14-2010 at 07:37 PM. |
01-18-2010, 10:14 AM | #14 |
I have the hooker super comp headers for my 1970 truck with a bbc and they do not hang down.Work well with my combo but i am not sure about yours. I think that the exhaust runners are raise on that head? If so its gonna be in your best intrest to have a set built like royo said. because of the clearence problems with the headers being moved up with the exhaust ports being raised. Are you running the engine in the stock location with the 1974 engine mounts? there is several factors to take in consideration just trying to make sure you look at everything before you order something you cannot use.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 01-18-2010 at 10:17 AM. |
01-20-2010, 12:15 AM | #15 |
What did you guys use to make it work. I ordered some super comps
2841 headers? Motor mounts?? |
01-22-2010, 05:57 PM | #16 |
01-22-2010, 07:33 PM | #17 |
David6000,
Sorry about the late response. Check out the link in my signature, i have some photos in my build. They are #2455. I only had problems on the driver side. A little ball peen hammer fixed it in about 2 minutes. It was hitting my lower cont arm was all.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
