Old 12-17-2009, 11:20 PM   #1
HOGDADDY
HOGDADDY's Avatar
Window tint removal
Does anyone know the best way to remove old window tint? Thanks in advance.
HOGDADDY is offline   Reply With Quote
Old 12-17-2009, 11:37 PM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: Window tint removal
this is how i did mine, found in edge in the tint that lift up and rip then riped it all off, it will leave behind a film. to take the film off use some windex and a xacto blade and just scrape away it wont scratch the glass then when its all of get you some triple 000 stell wool and go over the window they will look brand new, check mine out i did the door glass.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 12-17-2009, 11:56 PM   #3
G-Ring
G-Ring's Avatar
On a hot sunny day take wet newspaper and stick it to the old tint. The ammonia and moisture will help but you'll still be left with good ole fashioned scraping.
G-Ring is offline   Reply With Quote
Old 12-18-2009, 12:41 AM   #4
qu1cks1lver56
qu1cks1lver56's Avatar
i used a heat gun and a razor blade scraper and peeled the old stuff off. then used some oops and a rag to get the glue off
qu1cks1lver56 is offline   Reply With Quote
Old 12-18-2009, 12:42 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum G-Ring.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-18-2009, 01:14 AM   #6
G-Ring
G-Ring's Avatar
Thanks N2TRUX. I finally broke my cherry after lurking around the site a few years.
Old 12-18-2009, 07:42 AM   #7
thump16
thump16's Avatar
The best way is to saturate the tint on a warm day and place a black plastic trash bag over the tint and let it sit for about 30 min or so. It should peel right off with no problems or if you have a tint shop near you, ask them if they would give you some of their tint remover. It works great and actually pulls the glue off in small jell pools and not the sticky mess you get when you use dish soap and water or windex.
thump16 is offline   Reply With Quote
Old 12-18-2009, 11:32 AM   #8
Damien
Damien's Avatar
I used a heat gun and 3M Citrus cleaner. Then cleaned the window with Zep 40 glass cleaner.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-18-2009, 11:49 AM   #9
Clyde65
Clyde65's Avatar
I used 409 and some heat, worked well, but you will need some good razor blades and something to hold them comfortably. Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
