Old 12-18-2009, 10:02 PM   #1
56 3100
56 3100's Avatar
1956 3100 build
hi everyone thought i would post up my progress of building my 56. i am going pro street with big block power.
56 3100 is offline   Reply With Quote
Old 12-18-2009, 10:40 PM   #2
56 3100
56 3100's Avatar
Re: 1956 3100 build
flat black after taking off some surface rust and cutting rear box sides for the hoosiers.
Old 12-18-2009, 11:45 PM   #3
56ClassicTruck
Re: 1956 3100 build
Man I love the look from the back with thought big tires.......did you shorten your rear end????
56ClassicTruck is offline   Reply With Quote
Old 12-19-2009, 12:02 AM   #4
56 3100
56 3100's Avatar
Re: 1956 3100 build
i am in process of cutting a ford 9''down to about 54" overall width. i have chris alston pro street 4 link for back . after christmas i will start fabbing some more on rearend and suspension.
Old 12-19-2009, 12:09 AM   #5
JML55
JML55's Avatar
Re: 1956 3100 build
Hi from Winnipeg, cool project you have there.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 12-19-2009, 12:41 AM   #6
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks jean-marc. we have you cold weather here now! i have been gathering parts for truck since i bought it in 1995 i figured it was time to start the build. it was fun to drive stock for a couple years with the pitina look?(right spelling). you could see massy ferguson on bottom of door faded in. some plumbing company name could be seen in another spot. what was funny is someone using drivers side inner roof for records. it had the amount of wolves and grass hoppers someone might have saw/counted plus acouple of oil change dates written in as well. i am waiting on a pair of rear fender tubs that would finish out the bed of truck . flange on tubs match bed stips when using wood bed.
Old 01-18-2010, 10:00 AM   #7
56 3100
56 3100's Avatar
Re: 1956 3100 build
hi chuck i hope it okay using you pic? i will look at you link how. i just emailed the guy i am getting my set of tubs from and it shows that . is the section on the spare tire well flanged like rest of lip at all? i have spare sections of bed strip so hopefully get really close. tubs will look kinda factory is part i like.
Old 01-20-2010, 08:56 PM   #8
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1956 3100 build
No the whole corner is completly missing. But if you plan to cut them down to make them narower you could use a section from the drivers side to finish off the passsenger side, I think. Not sure when I'll get to mine so I'll look to se what you do with your's! My pics are free for anyone to use!
ChuckDriver is offline   Reply With Quote
Old 01-20-2010, 11:43 PM   #9
50adrod
50adrod's Avatar
Re: 1956 3100 build
looking good. I was told not to mount my tank that way because the welds will eventually fatigue and leak due the weight. I ended up mounting mine with steel straps like they come from the factory. good luck with the build
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 01-23-2010, 04:53 PM   #10
56 3100
56 3100's Avatar
Re: 1956 3100 build
thats interesting about tank 50adrod. bit of a bummer chuckdriver about little bit of flange on wheel tub but we can make it work.a fellow member on this site is sending wheel tubs to me monday so that will help alot. i got 4link brackets to fit on housing today.finally making progress.
Old 01-24-2010, 12:36 AM   #11
nuke1
nuke1's Avatar
Re: 1956 3100 build
looking good fellow canuck. What are you using for housing ends? are you jigging it when welding just curious. Will be nice when done.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-24-2010, 11:13 AM   #12
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks there nuke1.yes goona use jig type that has bar through housing and solid ends that go in axle tubes. i have another housing that is close to width i need so i will cut end off that.
Old 03-14-2010, 01:44 PM   #13
ChuckDriver
Re: 1956 3100 build
Any updates?
Old 03-14-2010, 02:00 PM   #14
yukon ratrod
yukon ratrod's Avatar
Re: 1956 3100 build
looking good! nice to see more projects.
yukon ratrod is offline   Reply With Quote
Old 10-17-2011, 08:54 PM   #15
56 3100
56 3100's Avatar
Re: 1956 3100 build
hi everyone sorry i havent posted in a while i took abreak after seeing rust around windsheild area of roof. i didnt want to lose interest. i have since found a decent roof of an old fire truck for $250 better price than $900 dynacorn/goodmark replacement.i have made some progress on rear supension. 4 link crossmember is welded in. i mounted 6" hoop up top for 2 reasons: 1: i recieved wrong drop by mistake and it would have cost price of it or more to ship back.(wont see anyway)2. dropped hoop might scrape in a sloped spot in my driveway.9" housing is sand blasted end tapped in ready for welding. lower coilover mounts are on and set at 10 degree angle using tubing shock simulator. upper shock crossmemeber and track locator next then rear almost done!lots of measuring.
Old 10-18-2011, 07:24 PM   #16
56 3100
56 3100's Avatar
Talking Re: 1956 3100 build
last reply rtimed out for adding pics
Old 10-18-2011, 08:28 PM   #17
ChuckDriver
Re: 1956 3100 build
Nice tub! I had a set for a couple of years that I still need to install.
Old 10-19-2011, 03:21 PM   #18
mdstitt
Re: 1956 3100 build
I had that Alston's Chassisworks suspension in a previous truck and plan to put it in my '56 soon. It's a great suspension that handled great and had a really nice ride.
You should be pretty happy with that choice.
mdstitt is offline   Reply With Quote
Old 01-27-2012, 11:06 PM   #19
56 3100
56 3100's Avatar
Re: 1956 3100 build
more soon.
Old 01-27-2012, 11:42 PM   #20
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 1956 3100 build
Looking really good, really good.
Kabwe is offline   Reply With Quote
Old 09-19-2014, 12:22 PM   #21
56 3100
56 3100's Avatar
Re: 1956 3100 build
went to a local car show recently and got my motivation back. have to start back at finishing rear suspension soon. scored a really decent and complete Camaro subframe on the weekend.gonna do front old school way. lots of good info here so far and have no limit video. I have been on the fence about the Camaro vs mustang ii due to fact of weight of going with a big block and ac. the Camaro clip wins. if anyone looking for some aftermarket mustang ii see ad. got some sheetmetal cleaned of old paint and rust. usual bottom of front fender rust.
Old 09-19-2014, 04:05 PM   #22
JML55
JML55's Avatar
Re: 1956 3100 build
Good to see you back at it
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
Old 09-19-2014, 05:15 PM   #23
Speedbumpauto
Speedbumpauto's Avatar
Re: 1956 3100 build
Yea! There aren't that many of us pro streeters out there anymore.
Speedbumpauto is offline   Reply With Quote
Old 09-19-2014, 08:14 PM   #24
Kim57
Kim57's Avatar
Re: 1956 3100 build
Glad you got your motivation back.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-24-2014, 08:23 PM   #25
56ClassicTruck
Re: 1956 3100 build
Hope get to finishing your... Mean wail I'll start looking for my motivation lol..��
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
