frame swap
Anyone know if my 63 cab will go on a 71 frame? Got a good deal on a short frame my truck is a long bed. Want to shorten mine also gives me five lug w/disc brakes.
Re: frame swap
Try a search. I'm fairly certain that a similar question has been asked before.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
Re: frame swap
The rear cab mounts are higher for a 6x-66 vs. a 67-72. You'll need to raise the mount or build a spacer to make up the difference.
The front radiator support mounts will also require a similar mod. They're slightly higher & forward vs. the 67-72 frame. The radiator mounts attach to a crossmember/splash apron on the 6x-66's. The 67-72 frame have a different splash apron (different shape, different location, does not support the radiator). The front frame horns are a different shape. If running a roll pan the horns are cut off so that's not much of an obstacle. If a bumper is planned, you'll need to fab new mounts or graft the 6x-66 frame horns to the 67-72 frame.
Re: frame swap
So could I just lower the front mounts, maybe notch the cab? Kinda like a body drop? Could I use the mounts off the 63 frame? Thanks for the info guys!
#5 | |
Re: frame swap
Seems the easiest way is to use a spacer in addition to the rear cab mount. Since the front radiator support mount has to shift forward & up, it would be easier on that one to just relocate the existing bracket. Another thing to consider..... I've always heard 60-62's had different oreintation on the cab mounts vs. 63 & later trucks. I've never crawled under & looked @ a 63 to make sure if that year break-down is 100% correct. I know the cab mounts on a 64 are similar & I'm assuming your 63's are like the 64's. You might want to verifiy this to be 100% sure (60-62's cab mounts had longer mounts that were farther out-board on the cab floor; 63-72's should be closer to the frame ~2" or so....).
Member of the longbed union.
Re: frame swap
It might be less work and easier to just swap over the 71 stuff to the 63 frame and cut the 63 frame down for a short bed!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Re: frame swap
Thanks guys, I am picking up the frame this week. Hopefully I can get some pics posted this weekend. I will take some measurements and let you know what I decide. The bed floor really isn't a problem I was going to raise it anyway.
Re: frame swap
one more point to ponder; the power steering box bolts right up to the 71 frame
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
Re: frame swap
I thought about that too. I want this truck to sit as low as possible but I want to drive the wheels off it!
Re: frame swap
If you end up going witht he 63, you can buy the adapter from captinfab for the gear box
Re: frame swap
Re: frame swap
another one
Re: frame swap
what do you guys think about a darker blue (flat) with red wheels and red flake on top?
![]() Last edited by 63 extreme low; 12-21-2009 at 02:28 AM. |
Re: frame swap
Like this. Sorta
#15 |
60-66 Nut
Re: frame swap
It would probably be the easiest to transfer the cab mounts and radiator support mounts from the '63 frame to the '71 frame along with the radiator crossmember and front frame horns.
