12-21-2009, 05:52 PM | #1 |
Hub Help Please
I have a 69 CST that needs a new front hub ASAP. The outer bearing race has eat up the inside of the hub. Where can I purchase a new one from? I did not see anything on LMC site. This is for a 1/2 ton 6 lug drum brakes.
Thanks for any help.
'69 Chevy CST 383 Stroker TH400 |
12-21-2009, 07:44 PM | #2 |
Re: Hub Help Please
Just to clarify, do you need a spindle or the drum hub?
12-21-2009, 09:44 PM | #3 |
Re: Hub Help Please
the actual hub not the spindle
12-21-2009, 11:35 PM | #4 |
Re: Hub Help Please
I don't recall ever seeing the hub offered through the aftermarket. You'll prob need to hit the local wrecking yards or maybe now's the time to upgrade to discs?
If that's not an option, you can get a $25 subscription to this site that will allow you to post a 'Want To Buy' ad in the classifieds section of the board or you can search the classifieds to see if someone is already offering what you need for sale. $25 isn't a tremendous amount & helps keep this place going (plus allows you to buy/sell on a limited basis for a year).
