Bed wood miss drilled on 55 AD
I got my wood bed lit from Classic parts and finished the wood installed the side rails mounted the X members and installed the side rail wood. I went to install the second boards which has the front mounting holes and the holes don't line up in with the x member. everything is loose so I can make adjustments but the are off by 1/2 inch. I measured a 54 short bed that a guy owns in my neighborhood and in measures 2 1/2 inches end of board to center of hole. The boards Classic Truck Parts sent measures 2" end of board to center of hole. I paid the premium price of $30.00 for pre drilled boards and this is what I get? Where could I find what the hole measurements should be ? It was late and I could not call CTP. Would a 1951 short be different? when I got my parts and invoice it states very clear on the invoice " Bed mounting Hole Installation 1951 8 Board Short Stepside" under Item # it has "51 8BSS"
I am going to call them but would like some information before I do. Thanks a lot for the help. here is a pic. steve |
Re: Bed wood miss drilled on 55 AD
I would install the bolt with a lock nut the rear and continue the install. There is enough hardware to hold the wood down. Or you can call the vender and tell them!!
This is the Bed mounting bolt hole it goes through the bed x member and into he truck frame, This is on both sides, This hole has to line up in order for the bolt o hod the bed down. I am not concerned about holding the wood down.
in the Classic Truck Catalog the bed wood has a different # for 47-51,52-53,54-55. bed strips are the same way. for the short step,what did you order or did they ship the wrong parts?
