12-22-2009, 09:59 PM | #1 |
Drop spindles with stock springs
Right now I have drop spindles and what I believe are 2-3" lowering springs. I love the look, but I'm strongly considering going back to stock springs because I drag my headers on everything. I'd love to see some pics of anyone with this combo. I'd also remove the lowering blocks in rear and just run the lowering springs.
My other question is would my 235/60/15 look ridiculous with the truck a little higher up? |
12-22-2009, 10:53 PM | #2 |
Re: Drop spindles with stock springs
I have ECE drop spindles (2.5") and stock springs..... I believe the springs to be original to the truck which came with a big block and I have a 350 in it. Don't know if that makes much difference or not.... I can take some pics if you want... Also just wondering why you don't go with different headers and bring the exhaust up a little?
12-23-2009, 12:04 AM | #3 |
How low are you in the back will the front be alot higher than the rear
70 SWB STEPSIDE 70 BLAZER 09 challenger |
12-23-2009, 04:25 PM | #4 |
Well, I think if I went to stock front springs and removed the lowering blocks in the rear, the change f/r would be about the same.
Are the front springs easy to pull out and replace? Obviously I'd need to re-align the truck afterward for camber and toe.... As for going with different headers, any higher up, and they'll interfere even worse with my shift linkage than they do now, and the truck has a full new custom exhaust I'd rather not spend the money on modifying. Plus, the headers I have are ceramic coated and pricey.... |
12-23-2009, 11:01 PM | #5 |
An American Soldier
I have ECE 2.5" drop spindles with stock front springs. I have ECE 4" drop springs in the rear. Here's the stance I have:
Dan dan.brue@us.army.mil |
12-24-2009, 12:27 AM | #6 |
12-23-2009, 11:56 PM | #7 | |
laying low
12-24-2009, 07:41 AM | #8 |
ENGINE BUILDER
Boog is right. Put 235 70 15 tires on the front and 255 70 15 tires on the rear.
JIM ZAG |
12-24-2009, 12:54 PM | #9 | |
Redefining LowBudget
I have this combo on my truck...I'm bagged with cupped lowers and a c notch...with long headers they only drag if I'm at full dump and I'm on the crown of the road...on the flat theres about 1/2" clearance..... you could sell the tires you have and be on a new set for less $$ and work ....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-24-2009, 06:41 PM | #10 | |
They're on 15x8s with 4" backspacing. If I did what I'm talking about I'm sure I could clear the larger rubber. I too have the C notch in the rear frame. Last edited by D-Rat; 12-24-2009 at 06:42 PM. |
12-24-2009, 07:35 PM | #11 |
67-72 parts collector,…
I wouldn't change your drop at all.
Sell your headers and swap them for a set of Chevelle "shorty" headers. This is my '69 with a 5.5"/7.5" drop. |
12-25-2009, 12:25 AM | #12 |
I know this sounds dumb but do you have bump stops??
12-26-2009, 10:21 AM | #13 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-24-2009, 12:32 PM | #14 |
I'd love to swap tires, but the ones I have are brand new...kinda hard to want to sink another $500 in tires....I bought the truck as it sits now.
57larry, that truck looks great...that's what I wanted to see. thanks. |
