Old 12-23-2009, 04:03 PM   #1
The Big Green
22x9 Coys, 5, or 5.5bs?
I've got a '67 C10 laying frame. Which backspace are you guys running, 5in or 5.5in bs?
I've seen a few pics but it's been a while, so any pics you guys wanna post feel free to, because I love to see pics.
The Big Green is offline   Reply With Quote
Old 12-23-2009, 07:40 PM   #2
The Big Green
Re: 22x9 Coys, 5, or 5.5bs?
Got it! 5.5bs Coy! Nevamind guys.
Old 12-24-2009, 01:56 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
did you buy some?
bagged74 is offline   Reply With Quote
Old 12-24-2009, 09:37 AM   #4
Shane
Shane's Avatar
Originally Posted by bagged74 View Post
did you buy some?
Lord I hope so ...
Shane is offline   Reply With Quote
Old 12-24-2009, 10:24 AM   #5
The Big Green
No, but I like the Coys, and they look good on these trucks. JJ and I measured and I can run a 24x10 with a 6-lug conversion with 7bs, but there's a catch, I only have 29in before I get into the hood. I'm going with the Coys and a 295/30/22 probably, and that's 29dia.
Old 12-24-2009, 10:51 AM   #6
bagged74
its just $$$$$
bagged74's Avatar
So, I'm confused again?? 6 lug conversion and 24s is a long way from 5.5" backspace on a coys?? What's it gonna be?
Also a 265/35 would be approximately the same diameter but would be a better choice for the front since it's not as wide. 265/35 front 285/35 rear is a nice combo in my opinion
Old 12-24-2009, 02:06 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
24x10 with a 7" BS is the same as a 22x9 with a 6" BS.
Is a Coys 22x9 with 5.5" BS going to work?
Or is that 1/2" less backspace going to make the tire rub on your fender?
Old 12-24-2009, 11:43 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Get the Coys and rock on.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-25-2009, 12:49 AM   #9
lolife99
lolife99's Avatar
I'm running a 20x8 with a 5.25" BS on the front of my blazer.
The equilavent of that in a 22x9 would be a 6.25" BS.
But I'm not as low and I still have my inner fenders.
Here's how they tuck.
Old 12-25-2009, 01:39 AM   #10
bagged74
its just $$$$$
bagged74's Avatar
What about the 6 lug conversion? Is the boss wheel available in a 22 with a 7" or so backspace in 6 lug?
Trust me the 275/25/24s suck bad
Old 12-25-2009, 02:54 AM   #11
The Big Green
Boss 330 in a 22x9 5.75, or 6.25bs, and I could run a 22/24 staggered look. I'd have to do a 6-lug swap.
Boss 335 in a 22x9 with a 6.25bs, I stay 5-lug, but no staggered look because no 24 in this wheel.
Boss 313 in a 22x9.5 with 5.682 or 6.785 in a 6-lug, and I can do a staggered with the 24.
Old 12-25-2009, 03:20 AM   #12
FnLow69
FnLow69's Avatar
i like the 313's the best of those three.
FnLow69 is offline   Reply With Quote
Old 12-25-2009, 03:44 AM   #13
bagged74
its just $$$$$
bagged74's Avatar
Looks like the 313 might be your best bet
Old 12-25-2009, 09:50 AM   #14
The Big Green
313 is similar to the 308 I had before so I like it. I like the multispoke look on these trucks. I can do a 22/24 in a 5lug but I can't do a choice of two bs in the 5, if I do the 6lug I can get the better, deeper offsets so that's what I'll do.
Old 12-28-2009, 04:20 PM   #15
The Big Green
What tires do you guys recommend for a 22/24? I have 29in before I hit the hood and I'm not sure before I get over the bedside, but I think it has notch for a 32dia tire. If I run a 22x9.5 with 6.785bs what 24 would be best? There's a 24x10 with 5.91 and 7.1.
Old 12-28-2009, 07:08 PM   #16
SCOTI
SCOTI's Avatar
10" w/the 5.91" would give the deeper dish (or the staggered offset). Only you can know for sure if you need that BS or the deeper 7.10". What year rear housing do you have?
A 265/35-22 would be 29.3" tall.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-28-2009, 07:42 PM   #17
lolife99
lolife99's Avatar
Can you order in both backspaces and try them?
The other choice is to measure.
Do you have a steel wheel (with no tire mounted) that you can bolt to the rearend and measure off of?
The only other option is to take it to bagged74's place and let him measure.
I don't know what else to tell you.
You need to measure both sides to verify how much the rearend shifts when you air it out.
Old 12-28-2009, 08:02 PM   #18
The Big Green
Pretty sure both bs will fit but which could possibly look better on back if I run the 22x9.5 with 6.785bs on front. I don't want the back sunk in too far. I'm guessing that the rear if 10in and 7.1 would be out almost level with the front, but out very little. The 7.1 may hit because the 10in I tried was 6.29 and it was close but I have measurements somewhere.
I'd love to have Bagged74 do measurements but I have a 24in 5.91bs and a tire mounted that I'll try tomorrow. I'd measure but I really like the seeing if it fits thing.
Old 12-28-2009, 08:34 PM   #19
lolife99
lolife99's Avatar
ok.
good luck.
Old 12-28-2009, 08:41 PM   #20
The Big Green
Anyone got a link to the 6lug rotors I need from ECE? I can't find the ones I need no matter what I search for on there.
Old 12-28-2009, 10:21 PM   #21
smbrouss70
smbrouss70's Avatar
Here you go. Link doesn't change when you're in the catalog, so I saved a picture with the part number. Call them, they'll make sure you get the right thing.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-28-2009, 11:03 PM   #22
The Big Green
Thanks for the pic. I hate computers so I always call and order. Also, thats not bad for a 6lug conversion.
Old 12-29-2009, 02:03 PM   #23
The Big Green
Boss 313, this is my wheel! If I measure from my old wheel correct it should fit fine. My old wheel was 20x8.5 with a bs of 5.1, that means my front clearance would be the same on a 9.5 wide wheel and 6.1, and a 10in on 6.6bs. I'm thinking the 9.5in and 6.78 would be ok maybe but it'll be sunk way back in because my old 20's were. I'm looking at a 9.5 with 5.75 which is .34 out farther than my old 20in, which should be fine. I'm tried a 22x10 that fit fine and was 6.3, so the 9.5 and 5.75 should be about the same on the outside right?
Wheel posted above in a 22/24, after weeks of looking thats the one I'm getting.
