12-23-2009, 10:15 PM | #1 |
squeaky coil spring
my front right coil spring is very sqeaky and i was wondering if there was anything i could do to help this since i have to drive down 2 miles of dirt road everyday
72 cheyenne super 83 chevy...4x4...454 |
12-23-2009, 10:50 PM | #2 |
Re: squeaky coil spring
There may be a piece of rubber that works as an isolater. After a while, the rubber will deteriorate or wear in two. You will need to split the a arms. On my truck, I didn't have to compress the spring, I just ran a ratchet strap through the center for safety. I jacked the truck up, put it on a stand, put the floor jack under the lower a arm, raised the jack until it just was about to lift the truck off the stand, loosened the lower ball joint bolt, whacked it with a hammer til it came loose, then let the jack down til I could pull the spring.
12-23-2009, 11:02 PM | #3 |
I've pulled apart 3 front ends and have yet to find a rubber isolator and none of them squeaked. Have you liberally greased both ball joints and both ends of each a-arm? Just for good measure hit the inner and outer tie rod ends.
12-23-2009, 11:25 PM | #4 |
anothe thing to check is the shock absorber mount//the stud thru the frame rail will loosen up elongating the hole allowing movement and squeaking
12-24-2009, 10:29 AM | #5 |
It has been a while since I have had a 72 front end apart, but my Malibu had isolators front and rear.
12-23-2009, 11:25 PM | #6 |
i greased everything posible today and it steal sqeaked loud. i felt the spring as i would push down on the hood and it felt as if the noise was coming from the coil itself
12-23-2009, 11:30 PM | #7 |
Did you check the bushings on the lower control arms? They're probably dry-rotted.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
12-23-2009, 11:43 PM | #8 |
laying low
If it's still a stock spring it fits so tight it's not likely to be the cause of the squeak. More likely is ball joint, control arm, sway bar or shock mount bushings. Hit em one at a time with water or wd40 then bounce it a bit to see when the squeak stops then you'll find the source.
02-04-2010, 08:47 PM | #9 |
Watch out for your cornhole !
They are steel. Dry rotting is for rubber bushings.
12-24-2009, 12:19 AM | #10 | |||
Union Electrician
I would bet the farm it is a shock, or a control arm bushing
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
12-24-2009, 12:52 AM | #11 |
I was having the same issue as well, not only do I believe my control arms were rotted but, once I dropped the coil spring out I had found that a coil had actually broke off of the spring. That leads me to believe that it may also have been the source with the two coils rubbing against one another.
12-24-2009, 10:27 AM | #12 | |
12-26-2009, 01:43 AM | #13 |
i put new shocks on and it still is loud as ever
02-04-2010, 08:33 PM | #14 |
is it a squeak or more like a ringing sound like it would sound if you hit the spring with a hammer but very fant mine has about the same thing and i can't find it ether mine didn't show up until i lowered the truck by cutting the spring
