![]() Join Date: Sep 2002
Valve Mufflers/Silencers
What's everybody using for air valve dump silencers? I found these. Do they quiet the noise pretty good?
I even thought about running the dump lines, (I have 2, for an Accu-Air manifold), to the exhaust pipes right after the mufflers. If I could weld a 12" or so length of 3/8" tubing to the pipe and attach the air lines to the end to keep the heat from melting them, I think that would keep the noise down pretty good, especially when the truck is running. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Valve Mufflers/Silencers
I would give SuicideDoors a call and ask them. I believe they sell these.
Anyone else know? |
AIRBAGPARTS.COM
Just use a muffler/silencer. They work great and take all of 2 seconds to install. Personally I have never used the ones you pictured, but have seen them many times. So that leads me to believe that they work. We also sell these different styles.
Redefining LowBudget
I'm listening to results
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
i use the ones on the top that avs jason pictured. they quite and you can adjust the dump speed
#6 | |
It'd be alot cooler if you did
I'm running these from Grainger. I like them because I can slow them waaaaay down.
To adjust them you just turn the screw on the end of them. http://www.grainger.com/Grainger/items/4ZJ85?Pid=search Last edited by smashingchuck; 12-28-2009 at 08:29 PM. |
I'm running the ones in the last pic that AVS JASON posted. They work fine for quieting the sound down ,but they're not adjustable for speed , mine is just as fast with or without them installed.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
