12-24-2009, 09:19 PM | #1 |
700r4 shifting problem
the truck will shift fine then 4th goes then 3 then 2 then 1 cut the truck off and crank it right back up it works fine then slowly it does it again. Has plenty of fluid and all the wiring looks good any Ideas?
bogey5 |
12-24-2009, 10:09 PM | #2 |
Its a Truck Thing......
Re: 700r4 shifting problem
Are you sure the TV cable is correct, If they are misadjusted, it will burn up the trans.
Are you sayin it downshifts all the way down to 1st when your driving it? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
12-25-2009, 12:00 AM | #3 |
yea as 4th slows I shift to 3rd locks backs up then starts same all the way to 1st turn it off start right back up it fine for a mile then starts again
bogey5 |
12-25-2009, 12:03 AM | #4 |
whats that you say
12-25-2009, 03:21 PM | #5 |
Gearhead and audio junkie
I think he's saying he'll go into 4th slow down and downshift normally all the way to 1st but it sounds like his torque converter is staying locked up and stalls the engine (if he has a lockup torque converter) when he stops.
12-25-2009, 06:22 PM | #6 |
sorry out of area just like it reads dangdest thing Ive seen going to shop monday.
bogey5 |
12-28-2009, 12:30 PM | #7 |
change the filter. sounds like its trying to stop up . pressure from the pump will suck trash into it and block pressure so start losing pulling power. when you stop and turn oof motor trans pump no longer builds pressure so some trash will fall off and you get full pressure until filter stops up again
