Old 12-27-2009, 08:31 PM   #1
cmabolt
cmabolt's Avatar
1972 chevy cheyenne 4x4 axles??
Hi all, I just acquired a 72 chevy 3/4 ton 4x4 cheyenne 4spd manual. I checked my axles to see if I had a dana underneath and to my surprise is had no dana id. It is a 10 bolt pattern with round pumpkin, but can't find any info. GM 10 bolt??
Any help/ resources would be great!
cmabolt is offline   Reply With Quote
Old 12-27-2009, 08:39 PM   #2
69TowRig
Re: 1972 chevy cheyenne 4x4 axles??
Stock would have been an open-knuckle disc-brake 44 in front with a 12-bolt rear. The brake setup is specific to 71-72 trucks and the shafts have 260X u-joints (smaller) instead of 297X joints (larger 73+).
Check this link for diagrams to help with identification. It is possible that a previous owner swapped out the 44 for a 10-bolt since they will bolt up without modification:
http://www.coloradok5.com/axleguide.shtml
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-27-2009, 11:20 PM   #3
Mudder
Mudder's Avatar
Welcome to the site. Moving this to the 4x4 area.
Mudder is offline   Reply With Quote
Old 12-27-2009, 11:54 PM   #4
b454rat
Should have the Dana 44 and an Eaton rear, maybe a Dana 60 rear. But if it's a 10 bolt front, it's been changed.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-28-2009, 11:04 AM   #5
69TowRig
Whoops, missed the 3/4 part. Most likely an Eaton HO52 rear, the D60s seemed to show up more on the 2wds.
-Chris
Old 12-28-2009, 12:25 AM   #6
2tons of fun
10b front are egg shaped.
when doing stuff like this it will serve you a lot better and save a lot of bs back and forth if you just post pics.
2tons of fun is offline   Reply With Quote
Old 12-28-2009, 03:08 PM   #7
Infanti
www.infantimachine.com
Infanti's Avatar
I have a 72 chevy 3/4 ton 4x4 with a 4 speed and the rearend is a Eaton HO52 frontend is a Dana 44 .
Infanti is offline   Reply With Quote
Old 01-06-2010, 11:33 AM   #8
cmabolt
cmabolt's Avatar
OK, after some research, I do indeed have dana 44 on front and ho52 on rear. I am doing a ground up on this truck and see that there are very few parts for the ho52. I was thinking about a 14 bolt on the rear. Has anybody done this swap and if so what are the mods that I can expect?
