Old 12-29-2009, 12:31 AM   #1
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Question Snow Troubles
Hey guys, I have been having some problems with snow and my truck.
I've sprayed the latches, hinges, and handles with WD. I've sprayed the seals with silicone and my doors are still freezing shut. I open my door and in the area between the outside of the door and the cab in the rear corners, snow is getting in there and freezing them shut.
My question is, how can I keep the snow from getting in there period? My truck has to be parked outside since mom uses the garage for her car. So any ideas are welcome.
Benjamin.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 12-29-2009, 01:00 AM   #2
creamsicle68
Re: Snow Troubles
when my doors freeze up in the winter i just take a cup of hot water out with me in the morning and pour it around the top and rear edge of the door and thats always worked for me.
creamsicle68 is offline   Reply With Quote
Old 12-29-2009, 01:01 AM   #3
Anadrol
Anadrol's Avatar
Re: Snow Troubles
You're asking for something to crack if you do that, including the window.
Anadrol is offline   Reply With Quote
Old 12-29-2009, 06:57 PM   #4
creamsicle68
Re: Snow Troubles
i know in theory it would and should shatter the window, but my dad has done it for years and his dad did it for years. they even poured hot water right on the windsheilds to melt the ice and snow off them. it sounds crazy and alot of ppl wont do it but we do it all the time and havent shatterd a single window
Old 12-29-2009, 01:00 AM   #5
Anadrol
Anadrol's Avatar
Re: Snow Troubles
1. Replace that weather strip
2. I think there's a special weather strip on LMC that is a deluxe version or something
3. Take it up to a pro and ask them to shim the doors for proper alignment. Assuming you bought your truck from some other private seller, those doors could have been aftermarket and they could've been aligned improperly?
4. Cary a spray can of lock de-icer
5. You could coat the weather seals in vaseline, but I assure you, vaseline can freeze too! A vaseline/anitfreez cocktail might do the trick if you mix it well enough to the proper proportions
6. I doubt if it's actual snow getting in there. It's probably water. You open the door, snow gets in. You drive away, truck heats up, snow turns to water. you park, water freezes. You may never be able to keep water totally out of there.
7. Anyone without a garage needs a remote start. If you're carbureted, there's a cure for that too.
8. Thoroughly clear any snow before you drive. This is the most important step. When it's cold out, go start the truck to get it warming up, and while you're waiting, knock all the snow off. Get a big, good snow scraper stick with a brush so that you can brush the snow off really well too. That's your enemy. If there's lots of snow on there, it will later melt to water, and that water will freeze your doors shut.
Old 12-29-2009, 01:14 AM   #6
Scootin 81 C20
3/4 Ton Rodder
Re: Snow Troubles
1. Weatherstrips are good.
2. Didn't know about that. Will look into it.
3. Doors are original to the truck and have never been off of it from what the PO told me when I bought it.
4. Have one, funny thing is, it's in the glovebox.
5. Sprayed them with silicone. The seals aren't where it's freezing.
6. I'm sure it's snow getting in there, because I use tip 8 and I have driprails on my truck to prevent the snow from falling in there.
7. I don't have remote start, and I can't afford it. I go out and start the truck up about 15-25 minutes before I plan to leave and let it idle til I'm ready to go. And yes, it is carbed.
8. Already been using this tip.
Old 12-29-2009, 01:48 AM   #7
Anadrol
Anadrol's Avatar
Re: Snow Troubles
Well FYI, you can get a remote start so advanced that it will actually start your truck once every 5 hours for 5 minutes, all night long, to insure that your truck is ready to go in the morning.
You remote start it, it's ready to rock, and it heats up quick.
After that, snow isnt much of a problem.
Old 12-29-2009, 01:55 AM   #8
Scootin 81 C20
3/4 Ton Rodder
Re: Snow Troubles
It has a block heater to help with the cold startups.
Old 12-29-2009, 03:57 AM   #9
JordanK20
Re: Snow Troubles
Try using white lithium grease on the latches and hindges? Wd40 is alittle to thin and might be freezing causing the doors to stick. Spray the inside the button on handle as well...if u can spray inside that helps too. The door seals should be good with silicone spray...maybe try another type and wipe it down maybe to much silicone. Are the latches maybe getting stuck? Good Luck
JordanK20 is offline   Reply With Quote
Old 12-29-2009, 08:36 AM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Snow Troubles
go with Jordans Ideas...
#6 is your problem..if you can get it in for a few hours to warm/dry the truck out then spray it so it ca push any water out of the locks
2 things I don't use in the wnter is door locks and he E brake?? trust me it 8* out there now??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-29-2009, 12:27 PM   #11
mitch1965
mitch1965's Avatar
Re: Snow Troubles
Both my trucks sit outside year round, since my garage is filled with my motorcycle and projects. Here's what I've used for years.
1. Clean the door jams and seals really well with good soap and water. Use a brush to clean the door seal and get out the caked in stuff. Make sure to clean the hinges, latch area, etc. Dry it as good as you can.
2. Use either white grease or a thick spray lube on the latch and hinges.
3. Spray silicone all around the door jam, truck and door sides. Coat the seal really well, use a rag to evenly coat the seal.
4. Lastly, whenever washing the truck in the winter, dry the door jam areas.
This works for me every year, and I haven't had a problem yet. I learned all that as a kid in Illinois on the farm.
Hope it helps.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
Old 12-29-2009, 12:53 PM   #12
Scootin 81 C20
3/4 Ton Rodder
Re: Snow Troubles
Thanks guys.
Mitch, where in IL are you from?
Old 12-29-2009, 02:07 PM   #13
mitch1965
mitch1965's Avatar
Re: Snow Troubles
Born in Morris, lived in the country near Minooka, then Ottawa, then Ransom.(all samll towns). Went to high school in Dwight, graduated, then left the state with my parents. I still have 2 brothers and a sister in the area.
Old 12-29-2009, 02:18 PM   #14
68 TT
Still plays with trucks
68 TT's Avatar
Re: Snow Troubles
How about a car cover or tarp?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-29-2009, 02:14 PM   #15
Scootin 81 C20
3/4 Ton Rodder
Re: Snow Troubles
I know where all of those are because I live in Bureau Co. I'm just North of I-80 on Rt. 40, used to be State Hwy. 88.
Old 12-29-2009, 02:19 PM   #16
mitch1965
mitch1965's Avatar
Re: Snow Troubles
I come back to the Chicago area a couple times a year for work. I usually add a couple days to see family. This year, I'm hoping to come back so I can go to the Sandwich Fair. Loved the truck and tractor pulls as a kid. I think it's around labor day weekend.
Old 12-29-2009, 02:24 PM   #17
Scootin 81 C20
3/4 Ton Rodder
Re: Snow Troubles
May have to make it up there for a member meetup if you go..
I've thought about a cover or tarp, but I don't think it would work with my CB antennas on there.
I've thought about that foam tape you can get at the hardware store. Think that might work?
Old 12-29-2009, 02:34 PM   #18
68 TT
68 TT's Avatar
Re: Snow Troubles
You really only need to cover the cab so you might be able to work a small tarp around the CB masts and still cover the door gaps.
Old 12-29-2009, 08:31 PM   #19
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Snow Troubles
Throw a blanket over the cab!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-29-2009, 08:34 PM   #20
68 TT
68 TT's Avatar
Re: Snow Troubles
That was my suggestion
I don't know why you are having such a hard time with this. My trucks have always been parked outside and the only time I have ever had problems with the snow is if we get freezing rain. Maybe you are parked too close to the house and it is melting the snow into a sheet of ice.
Old 12-30-2009, 12:14 AM   #21
Benelli
Watchin the rust grow
Benelli's Avatar
Re: Snow Troubles
I like the lithium grease idea.
I've never had these problems with my pick up though so I really don't have any first hand experince to help you.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
