Old 12-29-2009, 09:49 PM   #1
3r!c84
Badass
3r!c84's Avatar
dip stick
ok i was putting my headers on and i pulled out the dipstick and cant figgur out how to put it back on? there is a tube sticking out from the block about 1/4inch out and its the same size as the dipstick tube i pulled out?
any help? did i brake it?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-29-2009, 10:59 PM   #2
mongoose
mongoose's Avatar
Re: dip stick
sounds like you broke your dipstick tube... time to buy a new one..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 12-29-2009, 11:07 PM   #3
3r!c84
Badass
3r!c84's Avatar
Re: dip stick
great.how do i get the rest of it out? put some wd40 to let it sit and pull it out? or not good with it around the oil?
-00 Saturn 5spd
1/4:13:90
Old 12-29-2009, 11:52 PM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: dip stick
Drop the oil pan and tap it out with a screw driver from the bottom up.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-29-2009, 11:56 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: dip stick
how hard is that.its a stock pan,will i have problems getting it out?
-00 Saturn 5spd
1/4:13:90
Old 12-30-2009, 12:02 AM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: dip stick
not to bad if you have some swivel socks and long extensions
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-30-2009, 12:10 AM   #7
78 Chevyrado
Re: dip stick
It may come out if you're careful by pulling it out. The wd-40 won't hurt the engine as long as you don't go nuts and fill up the pan. I'd try this first to save pan removal, but even if you break it off to where you can't get ahold of it, tapping it out from underneath will work. Just be careful not to cave in the end of the tube you're tapping on or it will deform and not come out easily.
Looks like you have a 2wd. If you have a small block 350 you can take the pan loose without moving the engine. Just unbolt the pan and if you can't get it out, rotate the crankshaft until you can get the pan out. The front throws on the crankshaft will block you from removing it, so you just rotate the engine until they're out of the way.
78 Chevyrado is offline   Reply With Quote
Old 12-30-2009, 12:15 AM   #8
3r!c84
Badass
3r!c84's Avatar
Re: dip stick
ok good ideas guys, ill try the wd40 first ,the work my way from there
its a sb305 ): with th350.
-00 Saturn 5spd
1/4:13:90
Old 12-30-2009, 03:20 PM   #9
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
Re: dip stick
mine is loose and tha headers are in tha way of tightening it up, i cant get 2 it
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 12-30-2009, 03:57 PM   #10
3r!c84
Badass
3r!c84's Avatar
Re: dip stick
been driving around all morning looking for some place that has a dipstick no luck but i got a tinny one its about 7 inchs long im gona try that
wish me luck
-00 Saturn 5spd
1/4:13:90
