88 k2500 stereo wiring diagram needed
just as it says i am needing an 88 k2500 wiring diagram i just bought a stereo for my truck and will be wiring it into my stock harness but i do not have the diagram. so if somone has one i would greatly appreciate it. i believe my truck came with a factory cassette player cause i had one and it had its own harness im not sure if that will change it but im adding that.
Re: 88 k2500 stereo wiring diagram needed
these colors go for just about all chevys 86-2002
orange is radio 12v black is ground yellow is switched power(thicker gage wire as there are 2 yellow wires) brown and gray not used CAP OFF WIRE tan is positive front left speaker gray is negative front left speaker lite green is positive front right speaker dark green is negative front right speaker brown is positive Left Rear Speaker yellow is negative Left Rear Speaker(will be the same gage wire as the rest of the speaker wires) dark blue is positive Right Rear Speaker lite blue is negative Right Rear Speaker standard wire colors for MOST after market stereos yellow is 12v constant red is switched 12v black is ground blue is power antenna (only used if has motorized antenna) blue/white stripe is remote on (for an aftermarket or factory amplifier) orange positive dimmer (usally not hooked up cap off) orange/black stripe negative dimmer (usally not hooked up cap off) white is positive front left speaker white/black stripe negative front left speaker gray is positive front right speaker gray/black stripe negative front right speaker green positive rear left speaker green/black stripe negative rear left speaker purple positive rear right speaker purple/black stripe negative rear right speaker Last edited by TheSunDanceKid; 01-19-2010 at 07:24 PM. |
