![]() Join Date: Jun 2009
Died at an intersection, DOH!
I appeal for help to the kind folks here as I've now officially exhausted my girlfriend's patience in picking me up from vehicle breakdowns.(this was #1 or '10..hopefully won't hit the 4 or 5 number I hit last year)
As I was driving through the city today after a 20minute trip to Home Depot my truck died as I stopped at a red light. It has stalled out before and usually starts by turning the key over but this time the starter just cranked but it wouldn't startup up. I hopped out(with hazards on..as a full city bus waited behind me along with the rest of traffic) and shot in some starter fluid to the carb and it had no effect, just more cranking and no starting. The radiator lines weren't especially hot and it wasn't overheating as far as I could tell, the lights and everything worked and it did crank so I knew the battery wasn't dead(though it is low nowfrom all the attempts at cranking). Finally I corralled some people walking by to help me push it into a parking spot and I left it there for the night to collect my thoughts and head over with a gameplan. I plan to charge the battery first thing, following that what should I do? What should I check? I'm guessing ignition maybe ? Gas gauge showed a quarter tank..going to put a gallon in just in case, it didn't chug or do any of that running out of gas stuff though and I would think the starter fluid would have at least gotten it to start for a second. It's a '67 C10 with the gmc 305 v6, turbo 400 transmission. Any help is most appreciated, just put this truck back on the road and it's my daily driver. |
Active Member
Re: Died at an intersection, DOH!
Spark? Do you have points or HEI? Fuel filter? Carb problems? Flooding out, needle and seat?
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
I have points not HEI(though this is my first car with a carb that uses points so I'm not sure how to change/check them).
I brokedown about 1 block from Autozone so I'll grab another fuel filter while I'm there and change that(I'm guessing it's right on the front of the carb). And I was having carb problems trying to get it started on the way to Home Depot, it started great first thing in the morning and turned over the 2nd time but when we left for the store I had to use starter fluid. It did startup right away on the way back but we weren't int the store long at all. I'm a novice on carbs so I'm not too familiar with how to diagnose a problem with it. |
sounds like a factory service manual might be a good investment
You need to determine if its a fuel or spark issue. If it won't fire with starting fluid down the carb its more than likely not a fuel problem. Check to see if you have fire. Take along an extra sparkplug hook it to one of your plug wires, ground it and see if you have spark while someone else cranks it.
Good luck, Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
I do have a manual in fact...just was hoping someone had had a similar stall/no start experience to echo their experience as I'll be working on the sidewalk w/ limited time due to parking regulations. I suppose I'll pull a spark plug and check for spark and take it from there.
Check for fuel by disconnecting the line before the carb.Crank it over and gas should gush out.If not,remove line going into the fuel pump from tank.Still no fuel?It`s not coming out of the tank (clogged strainer) or that part of the line is clogged.
If fuel is good check for spark.Remove wire from a plug and hold with a small gap away from the block.If spark is orange the coil is weak.If no spark remove coil wire from center of distributor cap and check or spark the same way.I no spark the coil or a connection to the coil is bad.Or,points are shut.Remove cap and rotor.turn engine until one of the four high spots on the shaft stops at the pad on the points that rides there.This is when the gap should be open at about .017.If not opening loosen screw holding points in.Gap and tighten screw.If no feeler gauges use something about as thick as Aluminum siding.Siding is .019 for woodgrain and .024 for smooth,so they should pinch on the siding a bit.(if that`s what you use).The condensor could be bad and caused the points to burn.The contacts will look nasty.I`d say it`s time for a tune-up:points,rotor,cap,rotor,at least.
Dan
![]() Join Date: Dec 2009
I would bet on it that you've got a bad coil.
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie |
I was leaning towards coil myself, would a coil contribute to hard starts? I've noticed I've been having them some recently in this truck
I'm betting bad points. If it was a fuel issue it would have started with the starting fluid. You need to do a complete tune up. I'd consider changing it over to an electronic distributor of some sort. HEI, Pertronix, MSD
Dan
yes if your coil has been slowly going bad it could be giving you some hard starts, untill now when it finaly went completely. Ive had that happen to me before with my nova, i made the mistake of not mounting the coil on the firewall... because i have an aluminum intake (which transfers alot more heat) it got the coil too hot and ruined it and shut me right down on a 90 degree day out on the highway. If it was me, id change the coil before anything else. Thier cheap, or you could borrow one from something else quick to try it. Good Luck!
The one good thing about where it died is that it is 1 block from autozone, hopefully they have a coil, points, and distributor cap and I can just replace the whole mess since the truck's existing stuff is all old as dirt.
When I was in high school, (yea, we road in covered wagons back then) if you didn't have a feeler gauge set with you, and wanted to check point gap. Use a match book cover. Single thickness was for points, and double thickness was for plugs. Worked good enough to get you out of a pinch. Just my $.02 .
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
#14 | |
OP, while the matchbook trick will work in a pinch, you really need a dwell meter to adjust the point gap correctly. Keep in mind that for each degree the dwell changes, timing will also change that number of degrees. Get a book or do a google search. While a point ignition is a simple system, the line between running well and not running at all is fairly thin.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-02-2010 at 10:47 AM. |
#15 | |
Redefining LowBudget
LMAO ..I was just thinking the same thing..measure a match book...there 17 thou.....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#16 |
70 Chevrolet=Obsession
Throw away that old distributor and coil and get an HEI. You won't regret it.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
#17 |
Running on empty
While you are at AZ buy a $10 remote starter switch... you won't be sorry you did
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
#18 | |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
#19 |
#20 |
x2 on the remote starter switch.
HEI coils go bad,too.With electronic you get no warning.It works one day then doesn`t.I`ve had HEIs strand me and never points.This truck was giving warnings for a long time before it died.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-02-2010 at 11:12 AM. |
#21 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
this will be helpful.
http://abbysenior.com/mechanics/ignition.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#22 |
I checked for spark today and looks like the coil is the culprit(though the points did look a bit worse for wear). I went to autozone to buy both and they didn't have either, my engine is the gmc 305 v6, anyone know of a equivalent coil from another model I could use as none of the local parts places had anything specifically marked for the 305?
#23 |
Dan
any coil for a points ignition system will work, theyre all pretty much universal, just get one for an old small block, im sure theyll have that.
#24 |
it's spark or fuel, easy testing for both
#25 |
LIGHT' EM UP!!!!!!!!!!
have your girlfriend turn it over while you check each sparkplug with your finger lol
![]() ![]() ![]() BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND ![]() 1972 custom 10 longbed current 360 building a racing 355 |
